Have a DSP controller that I want to be able to view via Wifi.
Unit has a 100M Ethernet control. Via direct or Switch says the manual. But the 1200 does not see unit when plugged in. When directly plugged into PC its software sees it and works.
I can change the units IP and tried IP set 192.168.8.21 (1200 at default settings)
I am currently awaiting response about how to figure out the units Mac address. So that I can attempt to manually add it.
So finally just got a chance to do this.
What exactly should I be looking for?
I saved both dmesg and logread. Searched for the units IP but nothing. I do see my comps IP. Only connection I see.
