GL-SFT1200 Opal 4.x testing
I confirm. The repeater is now successfully connecting.
Will report any issues if any.
Thanks
Thanks for your feedback,I will check this issue.
After testing for a few days. It seems that the repeater disconnects after some time and doesn’t reconnect again until i login to the router and connect manually
One more thing.
I noticed that when Multi-WAN switches from Ethernet to repeater and VPN is connected. VPN disconnects and does not reconnect. So Internet connection is lost.
Thanks,I’ve forwarded it to the internal development team for analysis.
Any update on this coz the repeater keeps on disconnecting which renders it useless
Is this actively being developed as I have been holding testing for about 3 weeks now?
Is the issue repeater failing to connect? I’ll confirm that later.
Hi I’m new using GL.iNET routers, is there any bug/error in the 4.1.1 beta1 related to the VPN connection? When is it releasing as a stable version? I want to have those features specially dark mode for the web UI, thanks.
I decided to upgrade and so far it’s working good, I saw 2 minor problems (4.1.1 beta1)
  1. Seems like the router doesn’t save the dark mode setting and I need to activate it everytime I log in.
  2. The VPN traffic restarts after some time, I found out it restarts if the connection drops but that didn’t happen before, it would keep showing the total VPN traffic even if there were some connection drops.
I will share my feedback here just in case I find a bug.
Any info on when 4.x beta will be available?
