I loaded the 4.1.1 beta1 firmware on my Opal yesterday and set it up just as my Slate AX, very simple setup, just changed wireless SSID’s/PSK, LAN subnet and setup WireGuard. However, when trying to connect WG on the Opal it never completes fully and just logs this in cycle until I toggle to disconnect WG again.
Thu Dec 1 14:37:37 2022 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Thu Dec 1 14:39:04 2022 daemon.notice netifd: Interface ‘wgclient’ is now down
Thu Dec 1 14:39:19 2022 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Thu Dec 1 14:40:21 2022 daemon.notice netifd: Interface ‘wgclient’ is now down
I do however get a ping response through from the server side to the client side (Opal) when it is in this state. Anyone with any idea? I can also reach the Opal web GUI from server side.
I also faced the same issue, WG client stays in Connecting state.
Also, on stopping the WG Client, internet doesn’t work until the router is restarted.
@alzhao, I just tested the latest 4.2 (Jan 14) snapshot now, still unable to connect Repeater mode. That worked with the 4.1.1 beta1, but none of the 4.2 snapshots tested works for me. I get the same issue as @Maro has documented many times. Any chance this issue can be looked into?
I confirm. Tried the jan 14 snapshot build and still same issue. The router cant connect to any wifi uaing repeater mode.
Any possibility this can be looked into?
I have again tested the latest snapshop 4.2 (Jan 17) and still the same Repeater mode problem persists. Unable to connect to any wifi in repeater mode.
Hi,The developer is back in the office today to deal with this issue, I haven’t been given a timetable yet. will let you know as soon as it’s resolved.
Hi, I just tested and can confirm that the repeater now successfully can connect to upstream Wi-Fi. Will recreate my setup on this unit to see if my WG issues also now are working or not. Thanks!
Edit: I did a full reset of my setup and then when trying to reconnect again to the upstream Wi-Fi, the UI will not accept my PSK. Field border turns read. This seems to be some scripting behind the field not liking that I paste the value into the field.
Edit2: I managed to get everything for my use case working again, but the UI is kind of unusable when trying to paste into various fields. This should really be solved.
