GL-SFT1200 (Opal) Keeps Disconnecting and Reconnecting to WWAN
My new GL-SFT1200 Opal keeps disconnecting and reconnecting to WWAN.
Unit is in Repeater Mode. I tried turning off the WiFi output since I am connecting the computer through the LAN interface. No change.
I upgraded the firmware to 4.3.7. No change.
I tried a different WiFi network (I have two at my house). No change.
I tried 2.4 and 5 GHz bands, No change.
I checked the S/N ratio through Luci. It was -87/0 db. I moved the GL-SFT1200 closer to the WiFi access point, dropping the S/N to -50/0. No change.
I can see it is disconnecting when I ping the WiFi access point it is connected to. I can also see it in the System Logs.
I also have laptops and WiFi clients that don’t have this issue.
Ping times to the access point are very long with the average being 75 msec. It should be about 5 msec.
I checked the forum for ideas, and came up with nothing more. I’m out of ideas.
I am posting the last sections of the logs.
System Log:
Wed Feb 21 09:36:22 2024 user.info mwan3track[25416]: Detect ifdown event on interface wwan (wlan-sta0)
Wed Feb 21 09:36:22 2024 user.notice firewall: Reloading firewall due to ifdown of wwan ()
Wed Feb 21 09:36:22 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Wed Feb 21 09:36:22 2024 kern.warn kernel: [ 1472.859989] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:22 2024 kern.warn kernel: [ 1472.890873] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:22 2024 kern.warn kernel: [ 1472.921732] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:22 2024 kern.warn kernel: [ 1472.952644] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:22 2024 kern.warn kernel: [ 1472.983495] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.094368] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.205252] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 user.notice relay: Reloading relay due to ifdown of wwan ()
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.316146] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.426974] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.537836] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.648746] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.759624] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.870529] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:23 2024 kern.warn kernel: [ 1473.981376] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.092260] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.203133] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.314034] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.424872] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.535747] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.646619] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.757496] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.788360] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.819245] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.850128] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:24 2024 kern.warn kernel: [ 1474.881004] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:24 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Wed Feb 21 09:36:24 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Wed Feb 21 09:36:24 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-NETWORK-NOT-FOUND
Wed Feb 21 09:36:25 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Wed Feb 21 09:36:25 2024 kern.warn kernel: [ 1475.915679] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:25 2024 kern.warn kernel: [ 1475.946515] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:25 2024 kern.warn kernel: [ 1475.977380] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:25 2024 kern.warn kernel: [ 1476.008259] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:25 2024 kern.warn kernel: [ 1476.039136] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.150029] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.260912] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.371777] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.482657] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.593541] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.704402] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.815277] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1476.926152] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:26 2024 kern.warn kernel: [ 1477.037084] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.147942] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.258810] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.369692] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.480572] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.591431] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.702313] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.813189] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.844053] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.874933] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.905834] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:27 2024 kern.warn kernel: [ 1477.936698] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:27 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Wed Feb 21 09:36:27 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Wed Feb 21 09:36:27 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-NETWORK-NOT-FOUND
Wed Feb 21 09:36:28 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Wed Feb 21 09:36:28 2024 kern.warn kernel: [ 1478.971385] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:28 2024 kern.warn kernel: [ 1479.002231] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:28 2024 kern.warn kernel: [ 1479.033098] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:28 2024 kern.warn kernel: [ 1479.063974] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.094854] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.205737] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.316617] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.427516] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.538392] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.649297] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.760200] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.871035] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:29 2024 kern.warn kernel: [ 1479.981910] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.092774] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.203637] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.314513] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.425399] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.536286] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.647157] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.758035] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.868964] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.899814] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.930706] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.961579] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1480.992424] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:30 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Wed Feb 21 09:36:30 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: Trying to associate with c8:d3:a3:08:a8:33 (SSID=‘RLCResident’ freq=5180 MHz)
Wed Feb 21 09:36:30 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Wed Feb 21 09:36:30 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Trying to associate with c8:d3:a3:08:a8:33 (SSID=‘RLCResident’ freq=5180 MHz)
Wed Feb 21 09:36:30 2024 kern.warn kernel: [ 1481.028672] lmac[1] final dsss power is 19 ofdm power is 19
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.058775] lmac[1] {CTXT-0} Create channel context: freq=5180MHz bw=40MHz pwr=6dBm
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.066495] lmac[1] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.066513] lmac[1] final dsss power is 19 ofdm power is 19
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.078052] lmac[1] rc_init: station_id=12 format_mod=2 pre_type=0 short_gi=1 max_bw=1
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.086035] lmac[1] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.094141] lmac[1] {CTXT-0} unlink from {VIF-0}: status=4 nb_vif=1
Wed Feb 21 09:36:31 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=1
Wed Feb 21 09:36:31 2024 daemon.notice netifd: Network device ‘wlan-sta0’ link is up
Wed Feb 21 09:36:31 2024 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Wed Feb 21 09:36:31 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=1
Wed Feb 21 09:36:31 2024 user.notice mwan3track[25416]: Interface wwan (wlan-sta0) is offline
Wed Feb 21 09:36:31 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.094153] lmac[1] {CTXT-0} Delete channel context
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.604374] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.635235] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.666118] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.696982] lmac[1] final dsss power is 26 ofdm power is 26
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.727861] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.838758] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:31 2024 kern.warn kernel: [ 1481.949624] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.060526] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 user.notice relay: Reloading relay due to disconnected of wwan (wlan-sta0)
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.171358] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.282231] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.393115] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.504020] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.614889] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.725756] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.836667] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1482.947511] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:32 2024 kern.warn kernel: [ 1483.058378] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.169243] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.280129] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.391005] lmac[1] final dsss power is 27 ofdm power is 27
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.501881] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.532753] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.563645] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.594517] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.625392] lmac[1] final dsss power is 28 ofdm power is 28
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Wed Feb 21 09:36:33 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: Trying to associate with c8:d3:a3:08:a8:33 (SSID=‘RLCResident’ freq=5180 MHz)
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Trying to associate with c8:d3:a3:08:a8:33 (SSID=‘RLCResident’ freq=5180 MHz)
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.661212] lmac[1] final dsss power is 19 ofdm power is 19
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.691311] lmac[1] {CTXT-1} Create channel context: freq=5180MHz bw=40MHz pwr=6dBm
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.699026] lmac[1] {CTXT-1} link to {VIF-0}: status=0 nb_vif=0
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.699045] lmac[1] final dsss power is 19 ofdm power is 19
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.710624] lmac[1] rc_init: station_id=13 format_mod=2 pre_type=0 short_gi=1 max_bw=1
Wed Feb 21 09:36:33 2024 kern.warn kernel: [ 1483.718597] lmac[1] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
Wed Feb 21 09:36:33 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: Associated with c8:d3:a3:08:a8:33
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Associated with c8:d3:a3:08:a8:33
Wed Feb 21 09:36:33 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Wed Feb 21 09:36:33 2024 kern.info kernel: [ 1483.734593] hb-fmac 17800000.wifi-hb wlan-sta0: Add key for sta 13 (c8:d3:a3:08:a8:33)
Wed Feb 21 09:36:33 2024 kern.info kernel: [ 1483.743449] hb-fmac 17800000.wifi-hb wlan-sta0: Add key for vif(0), key index : 1
Wed Feb 21 09:36:33 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: WPA: Key negotiation completed with c8:d3:a3:08:a8:33 [PTK=CCMP GTK=CCMP]
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPA: Key negotiation completed with c8:d3:a3:08:a8:33 [PTK=CCMP GTK=CCMP]
Wed Feb 21 09:36:33 2024 daemon.notice wpa_supplicant[4274]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to c8:d3:a3:08:a8:33 completed [id=0 id_str=]
Wed Feb 21 09:36:33 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-CONNECTED - Connection to c8:d3:a3:08:a8:33 completed [id=0 id_str=]
Wed Feb 21 09:36:36 2024 daemon.info lua: (…pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:1239) connected to ‘RLCResident(c8:d3:a3:08:a8:33)’ channel: 36, spent 15s
Wed Feb 21 09:36:36 2024 daemon.notice netifd: Interface ‘wwan’ is enabled
Wed Feb 21 09:36:36 2024 daemon.notice netifd: Interface ‘wwan’ is setting up now
Wed Feb 21 09:36:36 2024 daemon.notice netifd: wwan (28695): udhcpc: started, v1.29.3
Wed Feb 21 09:36:36 2024 daemon.notice netifd: wwan (28695): udhcpc: sending discover
Wed Feb 21 09:36:39 2024 daemon.notice netifd: wwan (28695): udhcpc: sending discover
Wed Feb 21 09:36:42 2024 daemon.notice netifd: wwan (28695): udhcpc: sending discover
Wed Feb 21 09:36:55 2024 daemon.notice netifd: wwan (28695): udhcpc: sending select for 192.168.100.209
Wed Feb 21 09:36:55 2024 daemon.notice netifd: wwan (28695): udhcpc: lease of 192.168.100.209 obtained, lease time 86400
Wed Feb 21 09:36:55 2024 daemon.warn dnsmasq[1902]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Feb 21 09:36:55 2024 daemon.notice netifd: Interface ‘wwan’ is now up
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: reading /tmp/resolv.conf.auto
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain test
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain onion
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain localhost
Wed Feb 21 09:36:55 2024 daemon.notice netifd: wwan (28695): /lib/netifd/dhcp.script: line 62: netclash: not found
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain invalid
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain bind
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using local addresses only for domain lan
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using nameserver 1.1.1.1#53
Wed Feb 21 09:36:55 2024 daemon.info dnsmasq[1902]: using nameserver 1.0.0.1#53
Wed Feb 21 09:36:56 2024 user.notice mwan3[29285]: Execute ifup event on interface wwan (wlan-sta0)
Wed Feb 21 09:36:57 2024 user.notice mwan3[29285]: Starting tracker on interface wwan (wlan-sta0)
Wed Feb 21 09:36:57 2024 user.notice mwan3track[25416]: Stopping mwan3track for interface “wwan”
Kernel Log:
[ 1568.390837] lmac[1] ps_check_tx_status ps_retry(3) failed, notify host we are lost!
[ 1568.398541] lmac[1] {CTXT-1} unlink from {VIF-0}: status=4 nb_vif=1
[ 1568.398554] lmac[1] {CTXT-1} Delete channel context
[ 1568.405134] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 0
[ 1568.417736] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 1
[ 1568.425534] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 2
[ 1568.433052] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 3
[ 1568.440665] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 4
[ 1568.448259] hb-fmac 17800000.wifi-hb wlan-sta0: Del key for vif(0), key index : 5
[ 1568.507536] lmac[1] final dsss power is 26 ofdm power is 26
[ 1568.538409] lmac[1] final dsss power is 26 ofdm power is 26
[ 1568.569280] lmac[1] final dsss power is 26 ofdm power is 26
[ 1568.600131] lmac[1] final dsss power is 26 ofdm power is 26
[ 1568.631008] lmac[1] final dsss power is 27 ofdm power is 27
[ 1568.741900] lmac[1] final dsss power is 27 ofdm power is 27
[ 1568.852757] lmac[1] final dsss power is 27 ofdm power is 27
[ 1568.963641] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.074556] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.185396] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.296269] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.407146] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.518067] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.628935] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.739830] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.850703] lmac[1] final dsss power is 27 ofdm power is 27
[ 1569.961558] lmac[1] final dsss power is 27 ofdm power is 27
[ 1570.072433] lmac[1] final dsss power is 27 ofdm power is 27
[ 1570.183284] lmac[1] final dsss power is 27 ofdm power is 27
[ 1570.294213] lmac[1] final dsss power is 27 ofdm power is 27
[ 1570.405048] lmac[1] final dsss power is 28 ofdm power is 28
[ 1570.435941] lmac[1] final dsss power is 28 ofdm power is 28
[ 1570.466839] lmac[1] final dsss power is 28 ofdm power is 28
[ 1570.497733] lmac[1] final dsss power is 28 ofdm power is 28
[ 1570.528577] lmac[1] final dsss power is 28 ofdm power is 28
[ 1571.564228] lmac[1] final dsss power is 26 ofdm power is 26
[ 1571.595109] lmac[1] final dsss power is 26 ofdm power is 26
[ 1571.625933] lmac[1] final dsss power is 26 ofdm power is 26
[ 1571.656774] lmac[1] final dsss power is 26 ofdm power is 26
[ 1571.687660] lmac[1] final dsss power is 27 ofdm power is 27
[ 1571.798488] lmac[1] final dsss power is 27 ofdm power is 27
[ 1571.909361] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.020257] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.131139] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.242026] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.352884] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.463756] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.574635] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.685487] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.796359] lmac[1] final dsss power is 27 ofdm power is 27
[ 1572.907221] lmac[1] final dsss power is 27 ofdm power is 27
[ 1573.018109] lmac[1] final dsss power is 27 ofdm power is 27
[ 1573.128991] lmac[1] final dsss power is 27 ofdm power is 27
[ 1573.239859] lmac[1] final dsss power is 27 ofdm power is 27
[ 1573.350744] lmac[1] final dsss power is 27 ofdm power is 27
[ 1573.461600] lmac[1] final dsss power is 28 ofdm power is 28
[ 1573.492477] lmac[1] final dsss power is 28 ofdm power is 28
[ 1573.523369] lmac[1] final dsss power is 28 ofdm power is 28
[ 1573.554244] lmac[1] final dsss power is 28 ofdm power is 28
[ 1573.585130] lmac[1] final dsss power is 28 ofdm power is 28
[ 1574.619887] lmac[1] final dsss power is 26 ofdm power is 26
[ 1574.650741] lmac[1] final dsss power is 26 ofdm power is 26
[ 1574.681599] lmac[1] final dsss power is 26 ofdm power is 26
[ 1574.712475] lmac[1] final dsss power is 26 ofdm power is 26
[ 1574.743364] lmac[1] final dsss power is 27 ofdm power is 27
[ 1574.854252] lmac[1] final dsss power is 27 ofdm power is 27
[ 1574.965111] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.075986] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.186861] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.297762] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.408637] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.519516] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.630385] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.741275] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.852142] lmac[1] final dsss power is 27 ofdm power is 27
[ 1575.963021] lmac[1] final dsss power is 27 ofdm power is 27
[ 1576.073883] lmac[1] final dsss power is 27 ofdm power is 27
[ 1576.184768] lmac[1] final dsss power is 27 ofdm power is 27
[ 1576.295659] lmac[1] final dsss power is 27 ofdm power is 27
[ 1576.406527] lmac[1] final dsss power is 27 ofdm power is 27
[ 1576.517401] lmac[1] final dsss power is 28 ofdm power is 28
[ 1576.548278] lmac[1] final dsss power is 28 ofdm power is 28
[ 1576.579164] lmac[1] final dsss power is 28 ofdm power is 28
[ 1576.610037] lmac[1] final dsss power is 28 ofdm power is 28
[ 1576.640908] lmac[1] final dsss power is 28 ofdm power is 28
[ 1576.677210] lmac[1] final dsss power is 19 ofdm power is 19
[ 1576.707420] lmac[1] final dsss power is 19 ofdm power is 19
[ 1576.817573] lmac[1] {CTXT-2} Create channel context: freq=5180MHz bw=40MHz pwr=6dBm
[ 1576.825311] lmac[1] {CTXT-2} link to {VIF-0}: status=0 nb_vif=0
[ 1576.825328] lmac[1] final dsss power is 19 ofdm power is 19
[ 1576.836823] lmac[1] rc_init: station_id=14 format_mod=2 pre_type=0 short_gi=1 max_bw=1
[ 1576.844753] lmac[1] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
[ 1576.852850] lmac[1] {CTXT-2} unlink from {VIF-0}: status=4 nb_vif=1
[ 1576.852862] lmac[1] {CTXT-2} Delete channel context
[ 1577.362957] lmac[1] final dsss power is 26 ofdm power is 26
[ 1577.393871] lmac[1] final dsss power is 26 ofdm power is 26
[ 1577.424723] lmac[1] final dsss power is 26 ofdm power is 26
[ 1577.455615] lmac[1] final dsss power is 26 ofdm power is 26
[ 1577.486457] lmac[1] final dsss power is 27 ofdm power is 27
[ 1577.597346] lmac[1] final dsss power is 27 ofdm power is 27
[ 1577.708219] lmac[1] final dsss power is 27 ofdm power is 27
[ 1577.819093] lmac[1] final dsss power is 27 ofdm power is 27
[ 1577.929997] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.040852] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.151723] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.262628] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.373477] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.484356] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.595228] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.706106] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.816982] lmac[1] final dsss power is 27 ofdm power is 27
[ 1578.927850] lmac[1] final dsss power is 27 ofdm power is 27
[ 1579.038740] lmac[1] final dsss power is 27 ofdm power is 27
[ 1579.149596] lmac[1] final dsss power is 27 ofdm power is 27
[ 1579.260474] lmac[1] final dsss power is 28 ofdm power is 28
[ 1579.291352] lmac[1] final dsss power is 28 ofdm power is 28
[ 1579.322244] lmac[1] final dsss power is 28 ofdm power is 28
[ 1579.353123] lmac[1] final dsss power is 28 ofdm power is 28
[ 1579.383998] lmac[1] final dsss power is 28 ofdm power is 28
[ 1579.419795] lmac[1] final dsss power is 19 ofdm power is 19
[ 1579.449909] lmac[1] {CTXT-0} Create channel context: freq=5180MHz bw=40MHz pwr=6dBm
[ 1579.457624] lmac[1] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
[ 1579.457642] lmac[1] final dsss power is 19 ofdm power is 19
[ 1579.469202] lmac[1] rc_init: station_id=15 format_mod=2 pre_type=0 short_gi=1 max_bw=1
[ 1579.477229] lmac[1] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
[ 1579.492828] hb-fmac 17800000.wifi-hb wlan-sta0: Add key for sta 15 (c8:d3:a3:08:a8:33)
[ 1579.501574] hb-fmac 17800000.wifi-hb wlan-sta0: Add key for vif(0), key index : 1.
So no response. Anyone?
I have now run hours of testing and I have come to the following conclusions.
  1. The WWAN radio suffers greatly from adjacent channel interference.
    2)_ The WWAN radio has a low capture ratio, meaning it suffers from the inability to reject weaker signals on the same frequency.
  2. When the WWAN radio encounters either of the two above conditions, it randomly and frequently disconnects, and then reconnects.
I rearranged my network so there were no overlapping signals, which is not something people can do when they are traveling and using the networks provided by others. Changing WiFi channels and changing channel widths on access points eliminated the disconnects and reconnects.
In my opinion, the radio on this unit should be to be redesigned. WiFi radios on just about any device are more capable in interference conditions.
Are you talking about WWAN or WLAN?
I am referring to WWAN. I am connected to Ethernet on the LAN side.
The issue is once it disconnects from the WWAN, it has to go through a long cycle to reconnect.
This morning I tried disabling MultiWAN tracking in the Network menu as suggested in another thread. It didn’t fix the problem.
The bottom line is you need a strong signal and little to no interference from other WiFi signals. I could get fairly reliable performance with a signal of -50 db and 0 db noise. If you have a -80 db signal like I have with one of my access points, then forget it. Most laptops and phones will outperform the radio in the Opal.
It is more than interference.
The WWAN connection will drop frequently when:
  • 1 there is more than one AP with the same SSID around, and BSSID Lock is not used (use advanced settings at first connect, and set BSSID Lock)
  • 2 there is more than one SSID in the known network list in the same or other band (remove the others)
  • 3 When the uplink AP is using MPDU aggregation, then packets with more than 32 MPDU are dropped (the IEEE 802.11 defines the limit at 64, not 32), causing disconnects
  • 4 When a disconnect occurs (and no fixed IP address was set, but eg DHCP) with mode=router, then all open sessions and NAT are dropped before reconnect, even when returning to the same AP and SSID.
I am having a very similar issue.
When I am connected to the Internet via ethernet, and then I connect via 2.4 or 5 WiFi netowrks, at times the entire device stops working, WiFi suddenly goes down, and the light turns blue.
It happens so often that it makes it very hard to use it and when I use ethernet only the issue goes away.
What is strange is that I use a VPN, and so not only do I lose WiFi, but I also lose my VPN connection (going from white light to blue). I then am not able to access the router at all, any way, except for a hard reset.
When it first started happening, I was wondering if a neighbor was trying to hack my router, but I didn't see any unexpected clients with access. I also though a neighbor might be trying to disrupt my internet because I was streaming tv shows with the volume on too loud and they were using a device to jam the connection.
I even started to wonder if I was being hacked from the wan to the router, since I sometimes had technical issues while using my computer, leading me to wonder if someone was doing a buffer overflow attack. I also had things selected on my screen, and had to power off my laptop out of concern that someone had gained access.
I got this router from amazon. Amazon is notorious for taking returns and reselling them as new. I wonder if someone could have gotten the device, installed persistent malware, and then returned it in somewhat pristine condition. I don't remember it seeming used when I got it, it looked new. I have installed updated firmware and it didn't help at all.
It seems like this router is defective and I'm not sure if it's in the warranty period.
I have purchased a large amount of gl-inet products (over $500 at least if not more) and this is the first product from that had been such a hassle and horrible experience.
I'm probably going to make my own topic about this, because I'm not sure what to do. I don't know if the product is defective, if this particular unit is defective, or if this could be persistent malware or some other problem.
I am getting weird unexpected behavior all the time.
If I was being knocked off WiFi by the channel and band being too crowded, I wouldn't expect it to suddenly disconnect the VPN.
I am in a building with many people, in many small units, and many many WiFi routers. All the channels and bands are somewhat crowded.
Although my issue is not happening from the WWAN, the WLAN is probably using a similar part of the hardware and so it may be a similar issue.
