I’m running into a strange issue with my GL-SFT1200 (Opal). Until recently, I was able to use it in repeater mode where it would connect to my home router (either 2.4 GHz or 5 GHz) and still broadcast both 2.4 GHz and 5 GHz SSIDs for my devices at the same time.
Now, the behavior has changed:
If I connect the Opal’s uplink to my home router on 2.4 GHz, then only the 5 GHz SSID is broadcast. The 2.4 GHz SSID disappears.
If I connect uplink on 5 GHz, then only the 2.4 GHz SSID is broadcast. The 5 GHz SSID disappears.
In other words, whichever band is used for the uplink STA is no longer available as a local AP.
This looks like standard OpenWrt AP+STA band limitation, but it never behaved this way on the Opal before. With the same home router (non-DFS channels), both SSIDs used to be available.
Steps already tried:
Updated to latest stable and beta firmware builds
Factory reset
Removed and re-added Wi-Fi configs
Tested uplink on both 2.4 GHz and 5 GHz networks
Verified home router is not using DFS channels
Confirmed via uci show wireless that both radios are set to AP + one STA
Logs (logread, dmesg) don’t show DFS/radar events.
This problem looks exactly like the “fast lane” behavior on some extenders (uplink on one band, only broadcast the opposite band), but as far as I know the Opal isn’t supposed to enforce that.
My question:
Has there been a recent firmware change that forces this AP+STA limitation?
Is this a known regression on the Opal?
Should I stick to an earlier stable firmware, or is there a way to force one radio (e.g. 5 GHz) to handle both STA + AP again while the other radio stays AP-only?
Since going back to v4.3.25, it's been acting completely abnormal. It’s exhibiting the exact same strange behavior that I experienced with the Beta firmware.
I have two theories that might explain this mystery: first, there could be DFS (Dynamic Frequency Selection) channels lurking in the area, causing interference and instability; or second, I might have unknowingly connected to a DFS-enabled router, which is known to switch channels unexpectedly and disrupt normal operation. Whatever the case, it’s definitely not normal, and I’m on the lookout for a solution—or at least some clarity on this peculiar situation.
Thanks for sending over the repeater channel sync script — I’ve installed and tested it, and it’s working as intended. The 5 GHz channel now stays properly synchronized between the STA connection and the AP broadcast, which resolves the original channel issue.
However, I’m still noticing a recurring problem when the router is under heavy network load. Specifically, whenever I perform a full-speed download or run an internet speed test, the router briefly loses internet connectivity. It looks like the STA connection temporarily drops or resets — I lose internet access for a few seconds before it automatically reconnects.
What’s strange is that this behavior didn’t occur when I first configured the repeater setup about six months ago. At that time, the router maintained a stable STA connection even during high-speed transfers.
Could you help me identify what might be causing the STA link to drop under load?
Happy to share logs or run any diagnostic commands if that helps.
I ran both ping tests while under high load (running a speed test simultaneously). Here are the results:
Ping to primary router (192.168.1.1): ~4.4% packet loss, with latency spikes ranging from 5 ms up to 750 ms.
Ping to www.google.com: ~14% packet loss, with latency fluctuating between 16 ms and 1100 ms.
There’s noticeable instability both locally (to the main router) and externally (to Google). I’m not sure if downgrading to the previous firmware would fully address this, but I can try if you think it’s necessary.
Curious to know if that reverting back to an old firmware means I’m require to recreate the custom script setup again?
How is Opal connected to the primary router? If repeater, please connect to the 5GHz WiFi of the Primary router. If not, please let me know your topology.
I think can also try to downgrade to the old firmware version (without keep settings).
If the own AP/WiFi is abnormal after repeater connected to primary WiFi, please again execute the script I posted above.
