I downloaded the Beta Software (v. 4.7.2) and when i try to login and activate Surfshark I get an invalid login, despite the credentials being corrrect.
I know they are correct because my email gets multiple 2FA email codes, but duing the Login procedure on the Router, there is no ability to enter the 2FA code.
Reviewing the login instructions did not show where the 2FA code gets entered ?
How can I configure SurfShark on the Opal router ?
Thanks
GL Web UI does not support filling in 2FA code for the time being, we are aware this issue, and we have submited to PM team to improve the GL GUI.
You can disable SurfShark 2FA login item and then login in the GL Web UI.
You can login to SurfShark through the GL APP, as the APP has supported 2FA.
Thanks, I suspected these were the only options until a fix is developed.
I tired searching for the Surfshark App under the Applications Menu option, but nothing shows for SurfShark, do I need to download it from somewhere?
Please download the GL router management APP 'glinet' > plugins > VPN client > WireGuard configuration > profiles in router > SurfShark, and in APP login to the SurfShark username and password.
If SurfShark account enables 2FA, it will pop up and ask for verification 2FA.
