Hi folks,
I’m finding it impossible to get either the 5G or 2.4G radios in the SFT1200 (running V3.216) to work successfully in client (sta) mode.
I’ve tried everything including completely stripping back the wireless config to no-network and re-adding the client network, but nothing seems to work.
Here’s what’s happening:
- Under LUCI, in the wireless network section, I can click SCAN, and see the target network I want to join.
- I click join next to the SSID of the network I’m trying to join, and walk through the config of joining the network - so far so good.
- Once the new client network is configured (along with the new interface), I save the config. Looking at the logs, I can see a successful association with the AP of the network I’m trying to join. But this is where things go no further.
Despite successful association, Layer 2 connectivity is never fully established. The output of iwinfo shows the issues, with no bit rate or TX power, etc:
root@GL-SFT1200:~# iwinfo
wlan0 ESSID: "SOLARGUEST"
Access Point: 6E:83:C4:[redacted]
Mode: Client Channel: 11 (2.462 GHz)
Tx-Power: 0 dBm Link Quality: 58/70
Signal: -52 dBm Noise: unknown
Bit Rate: unknown
Encryption: WPA2 PSK (CCMP)
Type: nl80211 HW Mode(s): 802.11bgn
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: yes PHY name: phy0
The GUI shows “Wireless not associated”, but sometimes also occasionally shows info similar to the iwinfo output. But either way, the main network interface screen shows the interface status as “Error: Network device not present”.
I’ve tried multiple AP’s of different brands, I’ve tried stripping the MAC address and channel of the SSID, to let it choose, but nothing works.
I’ve been using OpenWRT for years, and have setup many OpenWRT routers as WiFi clients, so I’m generally familiar with the process. But to me this looks like a bug.
Here’s the log output of when the SFT1200 joined the client network:
Wed Sep 20 19:42:20 2023 daemon.notice wpa_supplicant[19927]: wlan0: Trying to associate with e0:63:da:[redacted] (SSID='SOLARGUEST' freq=2462 MHz)
Wed Sep 20 19:42:20 2023 daemon.notice wpa_supplicant[19927]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=1
Wed Sep 20 19:42:21 2023 daemon.notice wpa_supplicant[19927]: wlan0: Trying to associate with f0:9f:c2:74:6c:2d (SSID='SOLARGUEST' freq=2412 MHz)
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 826.210753] lmac[0] {CTXT-0} Delete channel context
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 827.531914] lmac[0] {CTXT-1} Create channel context: freq=2412MHz bw=20MHz pwr=20dBm
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 827.544758] lmac[0] {CTXT-1} link to {VIF-0}: status=0 nb_vif=0
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 827.544801] lmac[0] rc_init: station_id=1 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 827.558795] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Wed Sep 20 19:42:21 2023 daemon.notice wpa_supplicant[19927]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=1
Wed Sep 20 19:42:21 2023 kern.warn kernel: [ 827.737219] lmac[0] {CTXT-1} unlink from {VIF-0}: status=4 nb_vif=1
Wed Sep 20 19:42:22 2023 daemon.notice wpa_supplicant[19927]: wlan0: Trying to associate with e0:63:da:[redacted] (SSID='SOLARGUEST' freq=2462 MHz)
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 827.737258] lmac[0] {CTXT-1} Delete channel context
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 828.424685] lmac[0] {CTXT-2} Create channel context: freq=2462MHz bw=20MHz pwr=20dBm
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 828.437483] lmac[0] {CTXT-2} link to {VIF-0}: status=0 nb_vif=0
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 828.437517] lmac[0] rc_init: station_id=2 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 828.451515] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Wed Sep 20 19:42:22 2023 daemon.notice wpa_supplicant[19927]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=00:00:00:00:00:00 status_code=1
Wed Sep 20 19:42:22 2023 kern.warn kernel: [ 828.629974] lmac[0] {CTXT-2} unlink from {VIF-0}: status=4 nb_vif=1
Wed Sep 20 19:42:23 2023 daemon.notice wpa_supplicant[19927]: wlan0: Trying to associate with e0:63:da:[redacted] (SSID='SOLARGUEST' freq=2462 MHz)
Wed Sep 20 19:42:23 2023 daemon.notice wpa_supplicant[19927]: wlan0: Associated with e0:63:da:[redacted]
Wed Sep 20 19:42:23 2023 daemon.notice wpa_supplicant[19927]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Wed Sep 20 19:42:23 2023 kern.warn kernel: [ 828.630005] lmac[0] {CTXT-2} Delete channel context
Wed Sep 20 19:42:23 2023 kern.warn kernel: [ 829.576748] lmac[0] {CTXT-0} Create channel context: freq=2462MHz bw=20MHz pwr=20dBm
Wed Sep 20 19:42:23 2023 kern.warn kernel: [ 829.589432] lmac[0] {CTXT-0} link to {VIF-0}: status=0 nb_vif=0
Wed Sep 20 19:42:23 2023 kern.warn kernel: [ 829.589455] lmac[0] rc_init: station_id=3 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Wed Sep 20 19:42:23 2023 kern.warn kernel: [ 829.603221] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=0 r_idx_max=3 no_samples=10
Wed Sep 20 19:42:23 2023 daemon.notice wpa_supplicant[19927]: wlan0: WPA: Key negotiation completed with e0:63:da:[redacted] [PTK=CCMP GTK=CCMP]
Wed Sep 20 19:42:23 2023 kern.info kernel: [ 829.634837] lb-fmac 11000000.wifi-lb wlan0: Add key for sta 3 (e0:63:da:[redacted])
Wed Sep 20 19:42:23 2023 kern.info kernel: [ 829.643134] lb-fmac 11000000.wifi-lb wlan0: Add key for vif(0), key index : 2
Wed Sep 20 19:42:23 2023 daemon.notice wpa_supplicant[19927]: wlan0: CTRL-EVENT-CONNECTED - Connection to e0:63:da:[redacted] completed [id=0 id_str=]
And here’s my wireless config (note this is after I tried stripping out the SSID MAC and channel, but it made no difference allowing the SFT1200 to scan for these dynamically):
root@GL-SFT1200:~# cat /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option txpower_max '25'
option band '5G'
option hwmode '11a'
option netisolate '0'
option max_all_num_sta '64'
option path 'platform/17800000.wifi-hb'
option htmode 'VHT80'
option disabled '0'
option acs_noradar '1'
option country 'AU'
option legacy_rates '1'
option channel '52'
config wifi-device 'radio1'
option txpower_max '20'
option band '2.4G'
option hwmode '11g'
option path 'platform/11000000.wifi-lb'
option htmode 'HT20'
option disabled '0'
option country 'AU'
option channel 'auto'
config wifi-iface
option network 'wwan'
option ssid 'SOLARGUEST'
option device 'radio1'
option mode 'sta'
option key 'redacted'
option encryption 'psk2+ccmp'
I’ve tried using radio0 (5G) as the target network supports both frequencies, but get exactly the same results. So I’m at a loss! Any pointers most appreciated!
