GL-SFT1200 Opal - ZeroTier UI missing in 4.3.7 stable
Hello, I have several GL iNet routers and I appreciate that lately Zerotier is supported.
GL-SFT1200 has the zerotier package but is is missing the packages
gl-sdk4-zerotier and gl-sdk4-ui-zerotierview
that are present in other models.
When are you planning to release them?
Almost one year later, version 4.3.21 and still no Zerotier. Maybe not that important, but don't claim it in the documentation then. False expectations, make one loose all trust.
GL.inet with fake claims ? If SFT1200 is fraudulent, then why buying the more expensive devices, just to get more disappointments?
GL.inet should adjust their documentation, or fix the SFT1200. Zerotier missing is a minor issue, the totally unstable/unusable wifi uplink connection is a major issue.
Opal isn't powerful enough for ZeroTier on the 4.x firmware.
Then why not get SFT1200 OPAL out of the Zerotier "supported models" list? This will make correct expectations. ZeroTier - GL.iNet Router Docs 4
Ooooh there is no tick mark ...
By the way, the small and cheaper "Cudy TR1200" supports it.
You can run ZeroTier on Opal. The main issue is that sometimes it will be out of memory and the ZeroTier process will get kicked.
