GL-sft1200 POE camera doesnt join network
I have GL-SFT1200 with POE camera. The poe camera is powered off PSU than ethernet connected to lan 2. However I cant see it on the network? If I do the same setup on my home network I can see the camera so i know camera and the setup works.
Why wont SFT1200 pick it up?
Found this in logged. IDK what it means.
Tue Feb 20 15:45:34 2024 daemon.info dnsmasq-dhcp[1872]: DHCPDISCOVER(br-lan) 9c:8e:cd:2b:07:17
Tue Feb 20 15:45:34 2024 daemon.info dnsmasq-dhcp[1872]: DHCPOFFER(br-lan) 192.168.8.102 9c:8e:cd:2b:07:17
Tue Feb 20 15:45:34 2024 daemon.warn dnsmasq-dhcp[1872]: Error sending DHCP packet to 255.255.255.255: No error information
Tue Feb 20 15:45:37 2024 daemon.info dnsmasq-dhcp[1872]: DHCPDISCOVER(br-lan) 9c:8e:cd:2b:07:17
Tue Feb 20 15:45:37 2024 daemon.info dnsmasq-dhcp[1872]: DHCPOFFER(br-lan) 192.168.8.102 9c:8e:cd:2b:07:17
Tue Feb 20 15:45:37 2024 daemon.warn dnsmasq-dhcp[1872]: Error sending DHCP packet to 255.255.255.255: No error information
Do you have any other devices connected to your SFT1200 or is it the only router in the network?
I factory reset it. Now camera can join. But when connecting to home wifi it doesn’t get Internet
