log is from the client, both client and server are on 4.3.11
Also to mention that both client and server are in same network each setup as a router. Then there is a ISP router at the top hierarchy that I open a firewall port to the server.
Initially it worked fine for couple of days then I keep getting this message in the VPN client log.
I am outside my network, I get same errror and my outside IP is of the current outside ISP.
Which means connections is not going via my home VPN.
Does anyone has same errror ? Or can tell me what the error means.
Just to test my all devices and port forwarding I setup openVpn server and client. This works, which means my ISP router is doing port forwarding.
Its sad that no one can assist with this error, I might return those routers since they seem to useles.
If you need more assistance, please share an diagram of your network (using draw.io) plus your wireguard config (minus the private keys). See How to get support quickly
Not sure if related but my log files always Refetching server certificates
Fri May 24 12:27:51 2024 daemon.info dnscrypt-proxy[4638]: dnscrypt-proxy Server key fingerprint is C1A0:0E5A:2367:8813:6928:D7B4:DBE2:FFF3:CB95:6BCF:03C3:CC20:559B:043F:2F1D:E82A
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy Server certificate with serial #1 received
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy This certificate is valid
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy Chosen certificate #1 is valid from [2024-05-24] to [2024-05-25]
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy Using version 2.0 of the DNSCrypt protocol
Fri May 24 12:29:00 2024 daemon.info dnscrypt-proxy[4641]: dnscrypt-proxy Server key fingerprint is 9C3F:7B53:AC31:56B0:C4A5:A0E4:1089:F131:D765:09E5:6E05:D249:FCD8:F2D4:C13E:DC61
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy Server certificate with serial #1 received
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy This certificate is valid
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy Chosen certificate #1 is valid from [2024-05-24] to [2024-05-25]
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy Using version 2.0 of the DNSCrypt protocol
Fri May 24 12:29:39 2024 daemon.info dnscrypt-proxy[4642]: dnscrypt-proxy Server key fingerprint is 2D1E:3DF9:E361:BEED:A868:A41E:C699:AB91:BFFA:2C6C:EB2F:7B6D:5CD8:B41E:4D81:183A
Fri May 24 12:29:45 2024 daemon.info dnscrypt-proxy[4644]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:29:45 2024 daemon.info dnscrypt-proxy[4640]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:29:45 2024 daemon.info dnscrypt-proxy[4643]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:29:46 2024 daemon.info dnscrypt-proxy[4645]: dnscrypt-proxy Refetching server certificates
Fri May 24 12:30:00 2024 daemon.err dnscrypt-proxy[4644]: dnscrypt-proxy Unable to retrieve server certificates
Fri May 24 12:30:00 2024 daemon.err dnscrypt-proxy[4640]: dnscrypt-proxy Unable to retrieve server certificates
Fri May 24 12:30:00 2024 daemon.err dnscrypt-proxy[4643]: dnscrypt-proxy Unable to retrieve server certificates
Fri May 24 12:30:01 2024 daemon.err dnscrypt-proxy[4645]: dnscrypt-proxy Unable to retrieve server certificates
Frequent Certificate Refetches: The logs show that dnscrypt-proxy is frequently refetching server certificates. This is usually done to ensure that the certificates are up-to-date and the connection remains secure. However, the frequency here seems unusually high.
Certificate Validity Issues: Some log entries indicate that retrieved certificates are valid, but others show failures to retrieve them ("Unable to retrieve server certificates"). This suggests intermittent problems with certificate retrieval or validation.
Multiple Instances: The logs reveal multiple instances of dnscrypt-proxy running concurrently (e.g., 4640, 4641, etc.). This might be part of the configuration or a sign of unexpected behavior.
For the record ,
I also have a GL.iNet GL-AR300M, so I connected GL.iNet GL-AR300M and used same wireguard client config file and I dont have any of the errors I get with GL-SFT1200 . No errors related to wireguard neither Refetching server certificates.
GL.iNet GL-AR300M has 4.3.11 release3 .
This makes me believe issue is with GL-SFT1200, which I guess I am returning.
