Hi Everybody , I have a GL-SFT1200 (Opal) and when activate the SSID visibility Hidden? the WiFi shuts off and in consequence devices don't have internet, I'm showing a picture of the SSID visibility shown to have internet on devices!
would it be a problem of the software?
which Opal firmware version are you using?
Hi Thank you for the response , is that what you're asking for? if not?, would you tell me the route to get you the needed info?
Thanks in advance
thank you for confirming, just moving to the same version.
You mean download the upgrade of the same version and install it? ![]()
Yes just downgraded from the broken 4.7.2 beta to the 4.3.24 stable.
What devices lose access to the WiFi when you hide it?
Gentlemen?
I followed the instructions as you recommended, followed the instructions described here Firmware Upgrade - GL.iNet Router Docs 4
But...........
The same behaviour, the WiFi shuts off when the SSID is in option Hidden
Any recommendation will be well received!
Hi Everybody, although I'm using a VPN, there's certain amount of WiFi sniffers around using softwares to capture WiFi packages, through UDP/TCP protocols , or through STUN servers, and although I haven't noticed yet any signal of spoofing? I would like to enhance the security of my wireless network hidding the SSID of my WiFi, could you please provide me with the Email of technical support of this equipment? I registered it not much about 6 months ago and , I think it's yet on warranty for support! could anyone here please ? Help me out with my request? I'll be thankful in advance!
