After installing the latest version RM520NGLAAR03A04M4G via the Module Local Update option in the GL UI, the GL UI (Module Online Upgrade) shows the older version RM520NGLAAR03A03M4G as newer, and suggest to Upgrade, should I downgrade?
Please check the whole name of the current version of the modem, and post here:
AT+QGMR
Did you manual upgrade the modem version ever?
I have two GL-X3000. they each have a different modem FW. Each of them says the firmware is up-to-date. Which is the newest firmware available? I have listed the two firmware versions below obtained using the command AT+QGMR.
RM520NGLAAR01A07M4G_01.201.01.201
RM520NGLAAR03A04M4G_01.202.01.202
Second version is newer
Thank you. I figured that was likely the case with 201 vs 202 at the end. What about the difference in the R01 and R03. Does that matter?
Where can I get the latest firmware?
Unofficially:
R03 is main baseline, it is recommended to use R03
Latest R03 is:
RM520NGLAAR03A04M4G_01.204.01.204 released 2024-10-22
Latest R01 is:
RM520NGLAAR01A08M4G_01.206.01.206 released 2025-01-08
Thank you again. Much appreciated.
Hello, I just bought a GL-x3000 (june 2025) which works great.
My RM520N modem firmware version is RM520NGLAAR03A03M4G_01.201.01.201
Is the modem able to detect itself when a new firmware version available for the RM502N modem (through menu) ?
Is there a new version and should I upgrade it (it works well for now ..)?
Yes, the RM520N firmware version detection and OTA upgrade is available in GL GUI.
Please do not upgrade the modem firmware if it works well.
