I’ve just flashed by GL-USB150 with snapshot OpenWRT/Lede using imagebuilder. Something isn;'t working, but it’s hard to debug without UART serial console. I can see from the pinout it is supported, but the case is molded shut. Is there a trick to opening it?
The only way to open the case is by force.
Then you need a tape to tie them back after you repair.
Note: you can use uboot to change back the firmware without open the case.
Thanks. Thought as such. I’ll try a few uboot attempts before I crack the case. Leo
