Does this router support load balancing over many connections? specifically, can i load balance over 2 x 4G connections?
My intention is to use this in a vehicle using 12V.
Is there a recommended limit to antenna cable length/type if i want to connect to antennas (both wirless and 4G) mounted on the outside of the vehicle?
