GL-X2000 - modem error
The log file is flooded with daemon.err eco[8311]: call modem.get_sim_signal fail: connect "127.0.0.1 80" fail: Connection refused
*Firmware Type0713release2, v. 4.0
The modem.get_sim_signal message shows that eco was unable to connect to the local service on 127.0.0.1:80 .
To help determine whether this is only a local API/Web service issue or is related to the cellular connection, could you please help us check the following when the error occurs?
  1. Can you still access the GL.iNet Web Admin Panel normally?
  2. Is the cellular Internet connection still working normally, or does it also disconnect/reconnect at the same time?
  3. If the error is still occurring, please SSH into the router and share the output of the following commands:
netstat -lntp | grep ':80'
ps | grep -E '[n]ginx|[e]co'
logread | grep -Ei 'nginx|eco|oom|out of memory|killed'
You can refer to the tutorial on logging into the router via SSH:
These results should help us confirm whether the local Web/API service has stopped responding and whether it may be related to the cellular issue.
Thank you for your support and understanding.
The issue is solved: Ngix service must be running.
  1. the cellular signal LED is turned off without nginx service.
  2. daemon.err eco[8311]: call modem.get_sim_signal fail: connect "127.0.0.1 80" fail: Connection refused - nginx is stopped
Why does the cellular signal LED need webserver?
Thank you for the clarification and for confirming the behavior.
The cellular signal LED itself does not require a web server. In the current firmware implementation, eco obtains the modem signal information through a local API on 127.0.0.1:80, which depends on the nginx service.
Therefore, when nginx is stopped, eco cannot retrieve the signal value and the cellular signal LED can no longer be updated correctly.
