GL-X2000 Spitz Plus – Intermittent Internet connection loss / QMI timeouts (Quectel EG120K-EA)
I am experiencing intermittent Internet connection losses on my GL-X2000 Spitz Plus. I have carried out several investigations and would appreciate help from the GL.iNet team.
- Hardware and software
Component| Details
Router| GL.iNet GL-X2000 Spitz Plus
Modem| Quectel EG120K-EA
Modem firmware| EG120KEAAAR01A11M2G
USB ID| "2c7c:030b"
Router firmware| OpenWrt 19.07-SNAPSHOT
Kernel| 5.4.213
Build date| June 20, 2025
Modem driver| "qmi_wwan_q V1.2.7"
Connection mode| QMI / QMAP mode 1
QMI device| "/dev/cdc-wdm0"
Data interface| "wwan0_1"
Protocol| "qcm"
Carrier| Orange France
APN| "orange"
IP mode| IPv4 only
- Main symptoms
Several times a day, the router loses its Internet connection.
- Wi-Fi remains available.
- Devices stay connected to the router.
- Internet access stops working.
- The modem sometimes recovers automatically after several minutes.
On November 5, 2026, I personally observed an outage starting at approximately 22:17, with Internet access returning around 22:22.
Restarting only the modem connection from the router's web interface usually restores Internet access immediately.
- Investigations already performed
USB and hardware
- Checked the USB device and its interfaces.
- Verified that the modem remains detected during the investigated outages.
- Analysed USB and XHCI logs.
- Checked USB power management.
- USB autosuspend is disabled ("power/control=on").
- No physical USB disconnection or modem re-enumeration was observed in the "dmesg" logs corresponding to the November 5 outage.
The SanDisk SSD previously connected to the router has been unplugged and is not involved in the current tests.
Network and modem configuration
- Tested different IPv6 settings.
- Currently using IPv4 only.
- Disabled automatic SIM switching and APN polling.
- Disabled hardware acceleration during troubleshooting.
- Checked the modem interface and its associated DHCP interface.
- Inspected the GL.iNet modem monitoring scripts.
The modem uses:
- "modem_2_1" for the QMI connection.
- "modem_2_1_4" for DHCP.
- "wwan0_1" as the data interface.
GL.iNet script investigation
I inspected:
"/lib/functions/modem.sh"
In particular:
- "check_ip()"
- "modem_net_monitor()"
The "check_ip()" function can terminate the DHCP client when the IP address reported by the modem differs from the interface IP and connectivity checks fail.
The "modem_net_monitor()" function can bring the modem interface down and then back up when no IPv4 address is detected.
However, I have not established that either function caused the observed outage.
I also inspected:
"/lib/netifd/proto/qcm.sh"
The QCM process is launched using:
qcm -v -f /tmp/qcm.log -4 -n 1
The script creates a dynamic DHCP interface and uses "proto_set_keep 1".
There is no explicit QCM restart loop in this shell script.
- Most important finding: QMI timeouts
I enabled verbose QCM logging in "/tmp/qcm.log".
During normal operation, QMI requests work correctly:
- "QMIWDS_GET_PKT_SRVC_STATUS_REQ"
- "QMIWDS_GET_RUNTIME_SETTINGS_RESP"
The modem reports "CONNECTED" and correctly returns its IPv4 address, gateway and DNS servers.
However, several incidents show the same sequence.
November 5, 2026 – 22:17
At approximately 22:17:31:
requestQueryDataCall message timeout
requestQueryDataCall err = 110
QCM immediately attempts to restore the data connection.
At approximately 22:18:
requestSetupDataCall err = 0
requestGetIPAddress err = 0
QmiWwanThread exit
qmi_main exit
The previous data connection is successfully stopped and QMI clients are released.
QCM then detects the modem again:
- USB ID "2c7c:030b"
- "/dev/cdc-wdm0" detected
- Driver "qmi_wwan_q"
- QMAP mode 1
- Network interface "wwan0_1"
The modem subsequently reports:
PS: Attached, DataCap: LTE
A new data connection is established and the modem returns an IPv4 address.
Internet access returned at approximately 22:22.
Other occurrences
The same QMI timeout and internal QCM restart sequence was also recorded at approximately:
- November 5, 21:30
- November 5, 22:07
I was not present to confirm an actual Internet outage during these two events, so I cannot say whether they caused connection losses.
- Radio signal quality
At one point, the modem reported:
Parameter| Value
LTE band| B3 (1800 MHz)
Bandwidth| 20 MHz
RSRP| -110 dBm
RSRQ| -13 dB
SINR| 7 dB
The signal is not particularly strong, but the modem remains registered on the LTE network during the investigated incident.
I cannot determine whether radio conditions contribute to the QMI timeouts.
- What I would like GL.iNet to investigate
The main question is why QMI control requests time out with "err=110", even though:
- The modem remains physically connected via USB.
- The modem remains registered on the Orange LTE network.
- The QMI interface is still detected.
- QMI polling works normally between incidents.
Could this be related to:
- A QMI communication issue between the EG120K-EA modem and the "qmi_wwan_q" driver?
- A QCM / QConnectManager issue?
- A modem firmware issue?
- A GL.iNet monitoring mechanism or "netifd" terminating or restarting the QCM process?
- A known issue with this modem firmware or the GL-X2000 firmware version?
I would also like to know whether a newer router firmware, modem driver, QCM version or modem firmware is available to address this type of issue.
I can provide the detailed QCM logs and additional diagnostic outputs if required.
Thank you for your assistance.
