Device Model: GL.iNet GL-X3000
Firmware Version: 4.0 0704release5 | Modem: RM520NGLAAR03A03M4G_01.201.01.201 | set as PCIe interface
Network Mode: 5G NSA / 5G SA (issue occurs on both)
Frequency of Issue: Every 12–36 hours (intermittent, but consistent over time)
First error message in the LOGS, when it starts:
modem ip different, now regain ip
Issue Summary
The GL-X3000 modem experiences intermittent internet connectivity loss, specifically related to IP renewal or reassignment from the carrier after a period of stable use. This occurs approximately every 12, 24, or 36 hours.
When this issue occurs, it typically takes at least two reboots to restore connectivity.
Occasionally, after the first reboot, I receive the error message: "SIM not registered"
However, if I remove the SIM card and insert it into a smartphone, the phone connects to the internet immediately without any issues.
I have this add-on installed, but it doesn't seem to be triggering any actions — it's not restarting the modem, the network, or rebooting the device as expected.
Expected Behavior
The modem should seamlessly receive the new IP address from the carrier and reconnect to the network.
Actual Behavior
- After a certain uptime, the modem loses connectivity.
- It fails to obtain a new IP address.
- Sometimes reports the SIM as not registered.
- Manual rebooting and SIM re-seating are often required.
- The issue raises serious concerns in me, especially in unattended scenarios. For example, I can't reasonably expect my wife or son to perform multiple reboots or manually modify/re-apply APN settings to restore the connection.
Additional Information
- Inserting the SIM card into a smartphone always results in immediate connectivity, ruling out SIM or network provisioning issues.
- The problem seems to be related to DHCP lease renewal or how the carrier handles IP reassignment. I consistently receive a 192.0.0.2 IP address under the 5G connection details, but the device does not appear to be aware of its actual external/public IP address.
- As a result, the device becomes unreliable for home use, particularly for non-technical users.
Suggested Logs to Review
Wed May 28 22:56:15 2025 user.notice root: modem ip different, now regain ip ...
Wed May 28 22:56:15 2025 daemon.notice netifd: Interface 'modem_0001_4' has lost the connection
Wed May 28 22:56:16 2025 daemon.notice netifd: Interface 'modem_0001_4' is now down
Wed May 28 22:56:16 2025 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Wed May 28 22:56:16 2025 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Wed May 28 22:56:16 2025 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Wed May 28 22:56:16 2025 daemon.notice netifd: modem_0001_4 (26196): udhcpc: started, v1.33.2
Wed May 28 22:56:16 2025 user.notice firewall: Reloading firewall due to ifdown of modem_0001_4 ()
Wed May 28 22:56:16 2025 daemon.notice netifd: modem_0001_4 (26196): udhcpc: sending discover
Wed May 28 22:56:16 2025 daemon.notice netifd: modem_0001_4 (26196): udhcpc: sending select for 192.0.0.2
Wed May 28 22:56:16 2025 daemon.notice netifd: modem_0001_4 (26196): udhcpc: lease of 192.0.0.2 obtained, lease time 7200
Wed May 28 22:56:16 2025 daemon.notice netifd: Interface 'modem_0001_4' is now up
root@yesterday:~# gl_modem -B 0001:01:00.0 AT AT+CGPADDR
+CGPADDR: 1,"42.1.5.152.136.26.21.182.0.0.0.0.0.0.0.2"
+CGPADDR: 2,"42.1.5.159.136.6.169.149.0.0.0.0.0.0.0.2"
+CGPADDR: 3,"0.0.0.0","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
+CGPADDR: 4,"0.0.0.0","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
OK
root@yesterday:~# ifconfig rmnet_mhi0
rmnet_mhi0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:192.0.0.2 Mask:255.255.255.224
UP RUNNING NOARP MTU:1420 Metric:1
RX packets:422067 errors:0 dropped:0 overruns:0 frame:0
TX packets:607769 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2280063872 (2.1 GiB) TX bytes:93235666 (88.9 MiB)
Today I have disabled a few services, and I will monitor this.
Please advise on any patches, settings, or diagnostic steps to further isolate or resolve the issue.
Ideally, I would like the modem to automatically reconnect whenever the connection drops.
So far, the longest uninterrupted connection I've had was 1 day and 12 hours .
