GL-X3000 Beta firmware 4.4.13 glitch
Thanks for adding the ability to install Module firmware with the latest Beta release. So much easier for newbies to do this now! However, I have noticed that the system is showing that there is a newer module firmware version available for download even though I'm using the latest version. And if you click on upgrade, it actually downgrades the firmware to the previous RM520NGLAAR03A03M4G_BETA_20240521C_01.200.01.200.zip version and no longer shows that there is an even newer RM520NGLAAR03A04M4G_01.202.01.202.zip version. Instead, you have to manually install this version. Looks like this feature needs a little tweaking.
Opera Snapshot_2024-09-22_093847_192.168.21.1
We haven't tested this version yet
There may be problems
There is a risk of upgrading, we do not push
You can try manual upgrade, just as you would if you tried beta firmware
I totally understand your perspective and concern about running a version not yet tested. I was merely stating that the interface is showing that an update is available when there actually isn't and after clicking on the update button, the unit actually updates to a previous version.
I'm sure that it operates as expected as long as your not running an untested and newer firmware version than is saved on your servers. Thank you for the feedback and I appreciate the fact that the feature was added.
Where is this screen located at?
EDIT: NVM. Found it. :slight_smile:
System -> Upgrade — There's a new section below the "Firmware Online Upgrade" section.
