i cannot connect to mobile internet automatically after restart my device, i have to disable PIN code or
enter PIN code manually with modem code AT+CPIN=”XXXX”
(after that, everything is running fine and i get 30 Mbit with 5G instead of 10 Gbit with 4G)
else there is a message “Sim Card is locked”
i have tried everything, edit profiles 20 times, even installed modem manager and reset my device, used second sim-slot,
lost hours but no chance.
it is the same problem another user have got with the same provider:
(you can see the error message in german in this link (first picture))
I want to use a VPN provider and if someone who has access to the router resets it
the connection is established without a VPN provider.
In this respect, the automatic PIN does make sense.
i wrongly have selected the answer an a solution,
but it is not a solution for me.
still got the problem!
