GL-X3000 configuration to use a T-Mobile Phone SIM card
What is the configuration on the GL-X3000 to use it with a T-Mobile phone SIM card (Magenta Max, unlimited data) instead of the regular TMHI SIM card, looking for a reliable and sustainable solution, that will not get blocked and line canceled by the carrier over time, thanks
May I know can this SIM card work normally on X3000?
If it works, no additional configuration is required.
If you are worried about these situations, you can contact support@gl-inet.com for technical support from cellular experts.
