Glad it worked. No idea why its like that. Ive emailed sales person from the beta about it many times with no response. I have a feeling they dont know why its not working.
Hi Chimichanga:
Can I check this issue remotely?
Thanks!
Let me know if you need any more help with this
Please share your device with the cloud platform.
Account: gl.inet_support
Thanks!
Hi Dominion7574:
I need to actually look at some information remotely and do some debugging to determine the exact cause.
Is your SIM card a static IP?
Thanks!
No just a nornal T-mobile business tablet sim (public ip). Ill see if I can set it up for you. Tons of people having this issue so you should just be able to get a tmobile sim and test it.
Thank you very much.
When the above issue occurs, help to execute the AT instructions: AT+CGPADDR.
Then help to check ip obtained:
Happy to share as I am having same issue when not using 4.3.0. Added device to cloud. Don’t see where to share it.
Edit: Shared device with gl.inet_support
The following firmware makes some adjustments for this issue. You can test the new firmware:
So far so good. Ill let you know tomorrow after more testing.
