GL-X3000 Frimware / Uboot upgrade problem
I recently bought a GL-X3000 (Spitz AX) second‑hand.
From the first power‑on, when I tried to connect it to my ISP box, I could not access the router at all:
  • Only the power LED turns on
  • No other LEDs light up
  • I cannot reach the web admin interface in normal mode
After searching your documentation and forums, I saw there are known startup and U‑Boot recovery issues on GL‑X3000 devices and that they may require a U‑Boot/firmware fix.
So I followed the U‑Boot web recovery procedure:
I connected my PC directly via Ethernet to the router, with a static IP 192.168.1.2 / 255.255.255.0
I accessed U‑Boot at: http://192.168.1.1 and http://192.168.1.1/uboot.html
U‑Boot version shown: U-Boot 2022.07-rc3 (Mar 09 2023 - 16:20:34 +0800)
Then I tried to upload the official firmware file for GL‑X3000 from your download page:
  • Firmware: 4.8.3 (MTK / 21.02 / Active) for GL‑X3000
  • File name: x3000-4.8.3_release3-902-1106-1762433696.bin
But every time I try to flash this file via U‑Boot, I get:
I also retried multiple times, with a different browser and after re‑downloading the same firmware file, but the result is always the same: U‑Boot refuses the image as “wrong file”, even though it is the official GL‑X3000 4.8.3 firmware. I also tried the 4.7.4 frimware, result is the same.
Could you please advise if there is any further recovery method I can try at home ?
Additional details:
  • Model: GL‑X3000 (Spitz AX, 5G NR AX3000 Cellular Gateway Router)
  • LEDs: only power LED on, no other LEDs
  • U‑Boot: U-Boot 2022.07-rc3 (Mar 09 2023 - 16:20:34 +0800)
  • Firmware file used: x3000-4.8.3_release3-902-1106-1762433696.bin
  • Access only via U‑Boot web interface (no normal web UI available)
Thank you in advance for your help.
Best regards,
Try a different web browser. You are doing everything right.
Please refer to this guide:
  1. First, download the U-Boot file and update it
    File name: uboot-xe3000-20250225-md5-05fadd9da27314d41dbadc6fbd239b3d.bin
    Download: https://github.com/gl-inet/mt798x-boot/raw/refs/heads/main/bin/uboot-xe3000-20250225-md5-05fadd9da27314d41dbadc6fbd239b3d.bin
    Access this page to update: http://192.168.1.1/uboot.html
  2. Then, check whether U-Boot has been successfully updated. If it has, proceed to reflash the firmware
    Download: https://fw.gl-inet.com/firmware/x3000/release/x3000-4.8.3_release3-902-1106-1762433696.bin
If it still doesn’t work, please contact the seller to see if they can provide the original proof of purchase (sales channel and order number). Then send an email to support@gl-inet.com to request after-sales support.
I had exactly the same problem. I am afraid your router is f***ed!. I tried to serial revive mine it but the chip is fried. If you don’t have the original order number you’re screwed.
