hi,
yesterday i receive Gl-inet X3000 Splitz and inserted sim, change imei with 5G mobile imei, enable ipv6 and connected to internet.
But, internet stopped working after 5-7 minutes. not back after stopped and after stopped every time bellow same system log generated.
Sun Jul 28 09:00:16 2024 user.notice root: modem ip different, now regain ip ...
Sun Jul 28 09:00:16 2024 daemon.notice netifd: Interface 'modem_0001_4' has lost the connection
Sun Jul 28 09:00:16 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Sun Jul 28 09:00:16 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Sun Jul 28 09:00:16 2024 daemon.notice netifd: modem_0001_4 (24887): udhcpc: started, v1.33.2
Sun Jul 28 09:00:16 2024 daemon.notice netifd: modem_0001_4 (24887): udhcpc: sending discover
Sun Jul 28 09:00:16 2024 daemon.notice netifd: modem_0001_4 (24887): udhcpc: sending select for 192.0.0.2
Sun Jul 28 09:00:16 2024 daemon.notice netifd: modem_0001_4 (24887): udhcpc: lease of 192.0.0.2 obtained, lease time 7200
Sun Jul 28 09:00:16 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Sun Jul 28 09:00:16 2024 user.notice mwan3[24864]: Execute ifdown event on interface modem_0001_4 (unknown)
Sun Jul 28 09:00:17 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001_4 ()
Sun Jul 28 09:00:17 2024 user.notice nat6: Firewall config="cfg02dc81" zone="lan" zone_masq6="0".
Sun Jul 28 09:00:17 2024 user.notice nat6: Firewall config="cfg03dc81" zone="wan" zone_masq6="1".
Sun Jul 28 09:00:17 2024 user.notice nat6: Found firewall zone_name="wan" with zone_masq6="1" zone_masq6_privacy="1".
Sun Jul 28 09:00:17 2024 user.notice nat6: Setting up masquerading nat6 for zone_name="wan" with zone_masq6_privacy="1"
Sun Jul 28 09:00:17 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_postrouting" contains our MASQUERADE.
Sun Jul 28 09:00:17 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_input" contains our permissive DNAT rule.
Sun Jul 28 09:00:17 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_forward" contains our permissive DNAT rule.
Sun Jul 28 09:00:17 2024 user.notice nat6: Found device="rmnet_mhi0" for network_name="modem_0001".
Sun Jul 28 09:00:17 2024 user.notice nat6: Enabling IPv6 temporary addresses for device="rmnet_mhi0".
Sun Jul 28 09:00:17 2024 user.notice nat6: Accepting router advertisements on rmnet_mhi0 even if forwarding is enabled (required for temporary addresses)
Sun Jul 28 09:00:17 2024 user.notice nat6: Using temporary addresses for outgoing connections on interface rmnet_mhi0
Sun Jul 28 09:00:17 2024 user.notice nat6: Done setting up nat6 for zone="wan" on devices: rmnet_mhi0
Sun Jul 28 09:00:17 2024 user.notice nat6: Firewall config="cfg18dc81" zone="guest" zone_masq6="0".
Sun Jul 28 09:00:17 2024 user.notice mwan3[25290]: Execute ifup event on interface modem_0001_4 (rmnet_mhi0)
Sun Jul 28 09:00:17 2024 user.notice mwan3[25290]: Starting tracker on interface modem_0001_4 (rmnet_mhi0)
Sun Jul 28 09:00:20 2024 user.info mwan3rtmon[9577]: Detect rtchange event.
Sun Jul 28 09:00:20 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Sun Jul 28 09:00:20 2024 user.notice nat6: Firewall config="cfg02dc81" zone="lan" zone_masq6="0".
Sun Jul 28 09:00:20 2024 user.notice nat6: Firewall config="cfg03dc81" zone="wan" zone_masq6="1".
Sun Jul 28 09:00:20 2024 user.notice nat6: Found firewall zone_name="wan" with zone_masq6="1" zone_masq6_privacy="1".
Sun Jul 28 09:00:20 2024 user.notice nat6: Setting up masquerading nat6 for zone_name="wan" with zone_masq6_privacy="1"
Sun Jul 28 09:00:20 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_postrouting" contains our MASQUERADE.
Sun Jul 28 09:00:20 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_input" contains our permissive DNAT rule.
Sun Jul 28 09:00:20 2024 user.notice nat6: Ensuring ip6tables chain="zone_wan_forward" contains our permissive DNAT rule.
Sun Jul 28 09:00:20 2024 user.notice nat6: Found device="rmnet_mhi0" for network_name="modem_0001".
Sun Jul 28 09:00:20 2024 user.notice nat6: Enabling IPv6 temporary addresses for device="rmnet_mhi0".
Sun Jul 28 09:00:20 2024 user.notice nat6: Accepting router advertisements on rmnet_mhi0 even if forwarding is enabled (required for temporary addresses)
After off internet then Some time show :
Please help me for solve this issue.
Thank you
@Satyam500160
