GL-X3000 keeps dropping with T-Mobile SIM Card
I am using the X3000 with a T-Mobile Phone/Data Magenta Card that I have had for a number of years. This is not a TMHI Sim card. When the internet is up, I get over 400 Mbps download and over 40 Mbps upload. I recently down loaded the the latest firmware (Firmware 0704release5). Since doing so the router will drop (no internet available) and I have to unplug it and when it comes back on, the internet is back up. When the internet drops, all the lights on the router are solid green. Also, the admin panel under the internet tab, it says certification info highlighted. When I click on the link it takes me to a tmobile site to register the device. It says "Let’s get your IoT device ready for our network) Will that solve the problem? I didn't want to certify a SIM Card that may not be able to be certified on their site. I am confused at what has changed since the latest firmware. Can some help me with settings in the router that can resolve this issue. I am not real smart with this but if someone can walk me through the steps ( click internet than abc, and then xyz etc...) to resolve this it would be much appreciated. Thanks
Hello, just want to know, does the device automatically restore network connectivity after a drop?
Which network is the router connected to - 5G SA, 5G NSA or LTE?
Can you access the admin panel when the disconnection error occurs? If you can access the admin panel, please export the system log from the admin panel->SYSTEM->Log menu, and share it with us to check?
If you can connect to the internet using the Tmobile sim, you don't need to register the sim card once again.
When the internet drops, all the lights on the router are solid. The internet is not restored until I unplug it, wait 10 seconds and then plug it back in.
Not sure where to check that.
When discnnection occurs, my computer shows the "world icon" on my computer showing the internet dropped. I am unable to log into the router unless I unplug the router.
Thanks
Here is the Log. I have to load it multiple times because of the size.
Wed May 14 00:54:21 2025 kern.debug kernel: [ 30.917908] Set_AutoChannelSel_Proc: Alg = 3
Wed May 14 00:54:21 2025 kern.warn kernel: [ 30.923248] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (1e:00:a7:d9:4c:43), Reason 0x10
Wed May 14 00:54:21 2025 kern.err kernel: [ 30.932127] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.600907] [I][mhi0][__mhi_prepare_channel] Entered: preparing channel:14
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.610588] [I][mhi0][mhi_dump_tre] carl_ev evt_cmd_comp code=1, type=33
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.634990] [I][mhi0][__mhi_prepare_channel] Chan:14 successfully moved to start state
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.642920] [I][mhi0][__mhi_prepare_channel] Entered: preparing channel:15
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.652460] [I][mhi0][mhi_dump_tre] carl_ev evt_cmd_comp code=1, type=33
Wed May 14 00:54:22 2025 kern.debug kernel: [ 31.659353] [I][mhi0][__mhi_prepare_channel] Chan:15 successfully moved to start state
Wed May 14 00:54:23 2025 kern.debug kernel: [ 33.033490] BcnCheck start after 2900 ms (ra0)
Wed May 14 00:54:23 2025 kern.warn kernel: [ 33.047154] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (1e:00:a7:d9:4c:43), Reason 0x10
Wed May 14 00:54:23 2025 kern.err kernel: [ 33.056058] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Wed May 14 00:54:23 2025 kern.debug kernel: [ 33.157009] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Wed May 14 00:54:23 2025 kern.warn kernel: [ 33.164077] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:04:c9:d9:91:d2:ff
Wed May 14 00:54:23 2025 kern.notice kernel: [ 33.208956] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 04:c9:d9:91:d2:ff
Wed May 14 00:54:23 2025 kern.notice kernel: [ 33.218266] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 00:54:23 2025 kern.notice kernel: [ 33.227355] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed May 14 00:54:23 2025 kern.notice kernel: [ 33.268567] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed May 14 00:54:23 2025 kern.notice kernel: [ 33.410739] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.417705] 7981@C23L3,SelectClearChannelBusyTime() 1893: ====================================================================
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.429104] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 1 : Busy Time = 5940, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.440489] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 2 : Busy Time = 2561, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.451866] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 3 : Busy Time = 4085, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.463257] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 4 : Busy Time = 4056, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.474660] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 5 : Busy Time = 873, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.486054] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 6 : Busy Time = 3938, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.497448] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 7 : Busy Time = 2869, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.508831] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 8 : Busy Time = 877, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.520216] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 9 : Busy Time = 1372, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.531602] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 10 : Busy Time = 497, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.542999] 7981@C23L3,SelectClearChannelBusyTime() 1899: Channel 11 : Busy Time = 1719, Skip Channel = FALSE, BwCap = TRUE
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.554383] 7981@C23L3,SelectClearChannelBusyTime() 1902: ====================================================================
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.565803] 7981@C23L3,SelectClearChannelBusyTime() 2138: Rule 3 Channel Busy time value : Select Primary Channel 10
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.576327] 7981@C23L3,SelectClearChannelBusyTime() 2140: Rule 3 Channel Busy time value : Min Channel Busy = 497
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.586616] 7981@C23L3,SelectClearChannelBusyTime() 2145: Rule 3 Channel Busy time value : BW = 20
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.595587] 7981@C23L3,SelectClearChannelBusyTime() 2179: [SelectClearChannelBusyTime] - band0 END
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.604545] 7981@C23L3,AutoChSelScanNextChannel() 3092: Current channel = 6 , selected new channel = 10
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.741341] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.749629] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 106
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.756928] 7981@C23L3,rtmp_set_channel() 2892: (caller:AutoChSelScanNextChannel+0x260/0xd40 [mt_wifi]), Channel(10), quick_ch_change:1.
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.769410] 7981@C23L3,perform_channel_change() 2529: (caller:rtmp_set_channel+0x260/0x500 [mt_wifi]), Channel(10), quick_ch_change:1.
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.781740] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:perform_channel_change+0x23c/0xa70 [mt_wifi]), wdev_idx:0.
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.792645] 7981@C08L3,MacTableResetNonMapWdev() 2097: (caller:ap_phy_rrm_init_byRf+0x3e8/0x6b8 [mt_wifi]), wdev_idx:0.
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.813536] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : ra0
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.941871] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.950147] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 108
Wed May 14 00:54:24 2025 kern.warn kernel: [ 33.957207] 7981@C00L2,ap_phy_rrm_init_byRf() 2053: Scan(ACS) is running, can not do OverLapping scan here!
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.966937] 7981@C23L3,perform_channel_change() 2848: (Channel=10)
Wed May 14 00:54:24 2025 kern.err kernel: [ 33.973109] 7981@C23L1,DfsBuildChannelList() 4070: [RDM]: wdev is not 5G.
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.979889] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.987108] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Wed May 14 00:54:24 2025 kern.debug kernel: [ 33.987110] wait channel setting success.
Wed May 14 00:54:24 2025 kern.warn kernel: [ 33.987120] 7981@C08L2,APOverlappingBSSScan() 5200: leverage result of wdev(0@BN0), FallBack=1 (remaining 48880 ms)
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.995362] 7981@C08L3,UpdateBeaconHandler() 2092: Band0 BcnInitedRnd = 108
Wed May 14 00:54:24 2025 kern.notice kernel: [ 33.995437] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 00:54:24 2025 daemon.notice netifd: modem_0001 (5222): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Wed May 14 00:54:24 2025 daemon.notice netifd: modem_0001 (5222): sim is no ready
Wed May 14 00:54:24 2025 daemon.notice netifd: Wireless device 'mt798112' is now up
Wed May 14 00:54:24 2025 daemon.notice netifd: Network device 'rax0' link is up
Wed May 14 00:54:24 2025 kern.notice kernel: [ 34.024681] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 00:54:24 2025 kern.err kernel: [ 34.031355] 7981@C14L1,ba_resrc_rec_add() 1423: ba_resrc_rec_add Freeing previous Debug BA Rec 0000000082a61076
Wed May 14 00:54:24 2025 kern.notice kernel: [ 34.041620] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 00:54:24 2025 kern.warn kernel: [ 34.056755] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 04:c9:d9:91:d2:ff
Wed May 14 00:54:24 2025 daemon.notice netifd: Interface 'modem_0001' is now down
Wed May 14 00:54:24 2025 daemon.notice netifd: Interface 'modem_0001' is setting up now
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Wed May 14 00:54:24 2025 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Wed May 14 00:54:25 2025 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Wed May 14 00:54:25 2025 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Wed May 14 00:54:25 2025 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Wed May 14 00:54:25 2025 daemon.notice procd: /etc/rc.d/S90zerotier: disabled in config
Wed May 14 00:54:25 2025 daemon.err sms_manager: (sms_manager.c:195) start sms_manager on 127.0.0.1:53724, bus=0001:01:00.0
Wed May 14 00:54:25 2025 daemon.notice procd: /etc/rc.d/S94smstools3: Creating minimum spool directories
Wed May 14 00:54:25 2025 daemon.notice procd: /etc/rc.d/S95gl_ddns: /etc/rc.common: /etc/rc.d/S95gl_ddns: line 8: get_vpn_group: not found
Wed May 14 00:54:26 2025 kern.debug kernel: [ 35.705497] BcnCheck start after 3300 ms (ra0)
Wed May 14 00:54:26 2025 kern.debug kernel: [ 35.709973] BcnCheck start after 400 ms (ra0)
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN2G
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN5G
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S96led: setting up led POWER
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_led: Command failed: Not found
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_led: setting up led WLAN2G
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_led: setting up led WLAN5G
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_led: setting up led POWER
Wed May 14 00:54:26 2025 daemon.err nmbd[5606]: [2025/05/14 00:54:26.800133, 0] ../../source3/nmbd/nmbd.c:60(terminate)
Wed May 14 00:54:26 2025 daemon.err nmbd[5606]: Got SIGTERM: going down...
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_nas_sys: /etc/rc.common: line 31: /etc/init.d/nas_samba3: not found
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_nas_sys: /etc/rc.common: line 32: /etc/init.d/nas_samba4: not found
Wed May 14 00:54:26 2025 daemon.notice procd: /etc/rc.d/S97gl_nas_sys: sh: out of range
Wed May 14 00:54:27 2025 daemon.notice procd: /etc/rc.d/S99disk_manage: start app = /usr/bin/disk_manage
Wed May 14 00:54:27 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 04:c9:d9:91:d2:ff
Wed May 14 00:54:27 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 00:54:27 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 00:54:27 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff Hopper3-WiFi
Wed May 14 00:54:27 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 00:54:27 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 00:54:28 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: start app = /usr/bin/gl_nas_sys
Wed May 14 00:54:28 2025 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: start app = /usr/bin/gl_nas_sys
Wed May 14 00:54:28 2025 daemon.info eco[10950]: load config...
Wed May 14 00:54:28 2025 daemon.info eco[10950]: start collecting sim signals...
Wed May 14 00:54:28 2025 daemon.notice procd: /etc/rc.d/S99passthrough: uci: Entry not found
Wed May 14 00:54:28 2025 daemon.notice procd: /etc/rc.d/S99webdav_ser: start app = /usr/bin/webdav_ser
Wed May 14 00:54:28 2025 daemon.info procd: - init complete -
Wed May 14 00:54:28 2025 kern.debug kernel: [ 38.349481] BcnCheck start after 800 ms (ra0)
Wed May 14 00:54:29 2025 daemon.notice netifd: modem_0001 (8825): sh: 1: unknown operand
Wed May 14 00:54:33 2025 daemon.notice netifd: modem_0001 (8825): SIM not ready
Wed May 14 00:54:33 2025 daemon.notice netifd: modem_0001 (8825): Failed to parse message data
Wed May 14 00:54:33 2025 daemon.notice netifd: modem_0001 (8825): cat: can't open '/tmp/run/dual_sim/modem_0001/current_sim': No such file or directory
Wed May 14 00:54:34 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 00:54:34 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 00:54:36 2025 daemon.notice netifd: modem_0001 (8825): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Wed May 14 00:54:36 2025 kern.err kernel: [ 46.489937] [I][mhi_netdev_open] Opened net dev interface
Wed May 14 00:54:36 2025 daemon.notice netifd: Interface 'modem_0001' is now up
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:010] QConnectManager_Linux_V1.6.3.1
Wed May 14 00:54:37 2025 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:011] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:011] network interface '' or qmidev '' is not exist
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:011] netcard driver = pcie_mhi, driver version = V1.3.4
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:011] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:011] Modem works in QMI mode
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:029] cdc_wdm_fd = 7
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:041] Get clientWDS = 15
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:045] Get clientDMS = 1
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:049] Get clientNAS = 3
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:053] Get clientUIM = 2
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:056] Get clientWDA = 1
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:060] requestBaseBandVersion RM520NGLAAR03A03M4G
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:062] qmap_settings.rx_urb_size = 15360
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:063] qmap_settings.ul_data_aggregation_max_datagrams = 11
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:063] qmap_settings.ul_data_aggregation_max_size = 8192
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:063] qmap_settings.dl_minimum_padding = 0
Wed May 14 00:54:37 2025 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:076] requestGetSIMStatus SIMStatus: SIM_READY
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:080] requestGetProfile[1] fast.t-mobile.com///0/IPV4V6
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:082] requestRegistrationState2 MCC: 310, MNC: 260, PS: Attached, DataCap: 5G_SA
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:086] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:139] requestSetupDataCall WdsConnectionIPv4Handle: 0xe29726a0
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:798] requestDeactivateDefaultPDP WdsConnectionIPv4Handle
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:863] QmiWwanThread exit
Wed May 14 00:54:37 2025 daemon.notice netifd: modem_0001 (11667): [05-14_00:54:37:864] qmi_main exit
Wed May 14 00:54:37 2025 daemon.notice netifd: Interface 'modem_0001' is now down
Wed May 14 00:54:38 2025 user.notice kmwan: config json str={ "op": 1, "data": { } }
Wed May 14 00:54:38 2025 kern.debug kernel: [ 47.705618] kmwan: All nodes are deleted.
Wed May 14 00:54:38 2025 user.notice kmwan: config json str={ "op": 0, "data": { "sensitivity": 3000, "mode": "failover" } }
Wed May 14 00:54:38 2025 kern.debug kernel: [ 47.722922] kmwan: sensitivity and mode are set.
Wed May 14 00:54:38 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Wed May 14 00:54:39 2025 kern.warn kernel: [ 49.437747] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Wed May 14 00:54:39 2025 kern.warn kernel: [ 49.445876] 7981@C01L2,RTMP_COM_IoctlHandle() 1494: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Wed May 14 00:54:39 2025 kern.notice kernel: [ 49.453934] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 4
Wed May 14 00:54:39 2025 kern.notice kernel: [ 49.459556] 7981@C18L3,BuildChannelList() 507:
Wed May 14 00:54:39 2025 kern.debug kernel: [ 49.464166] wdev_attr_update(): wdevId4 = 92:83:c4:a5:a5:c8
Wed May 14 00:54:39 2025 kern.info kernel: [ 49.469752] apcli0: update addr to: 92:83:c4:a5:a5:c8
Wed May 14 00:54:39 2025 kern.notice kernel: [ 49.474893] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=4
Wed May 14 00:54:39 2025 kern.info kernel: [ 49.480892] mtk_ppe_dev_register_hook : ineterface apcli0 register (3)
Wed May 14 00:54:39 2025 kern.warn kernel: [ 49.491430] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Wed May 14 00:54:39 2025 kern.warn kernel: [ 49.499589] 7981@C01L2,RTMP_COM_IoctlHandle() 1494: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Wed May 14 00:54:39 2025 kern.notice kernel: [ 49.507650] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Wed May 14 00:54:40 2025 kern.notice kernel: [ 49.513330] 7981@C18L3,BuildChannelList() 507:
Wed May 14 00:54:40 2025 kern.debug kernel: [ 49.519861] wdev_attr_update(): wdevId5 = 9e:83:c4:a5:a5:c8
Wed May 14 00:54:40 2025 kern.info kernel: [ 49.525521] apclix0: update addr to: 9e:83:c4:a5:a5:c8
Wed May 14 00:54:40 2025 kern.notice kernel: [ 49.530763] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Wed May 14 00:54:40 2025 kern.info kernel: [ 49.538368] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Wed May 14 00:54:40 2025 kern.debug kernel: [ 49.545961] SetApCliEnableByWdev: I/F(apcli0) (enable = 0)
Wed May 14 00:54:40 2025 kern.debug kernel: [ 49.551639] SetApCliEnableByWdev: I/F(apcli1) (enable = 0)
Wed May 14 00:54:40 2025 daemon.info gl-repeater[3307]: (gl-repeater.lua:192) load wifi config...
Wed May 14 00:54:40 2025 daemon.info gl-repeater[3307]: (gl-repeater.lua:214) found radio mt798111
Wed May 14 00:54:40 2025 daemon.info gl-repeater[3307]: (gl-repeater.lua:214) found radio mt798112
Wed May 14 00:54:40 2025 daemon.info gl-repeater[3307]: (gl-repeater.lua: 16) load repeater config...
Wed May 14 00:54:40 2025 kern.info kernel: [ 49.657881] net rmnet_mhi0: link_state 0x0 -> 0x1
Wed May 14 00:54:41 2025 daemon.info gl-repeater[3307]: (repeater.lua:1448) no saved network
Wed May 14 00:54:41 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 00:54:41 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 00:54:45 2025 daemon.err usbmuxd[12431]: [00:54:45.767][3] usbmuxd v1.1.1 starting up
Wed May 14 00:54:45 2025 daemon.err usbmuxd[12431]: [00:54:45.767][3] Using libusb 1.0.24
Wed May 14 00:54:45 2025 daemon.err usbmuxd[12431]: [00:54:45.768][3] Initialization complete
Wed May 14 00:54:45 2025 daemon.err usbmuxd[12431]: [00:54:45.768][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Wed May 14 00:54:46 2025 kern.debug kernel: [ 56.269148] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Wed May 14 00:54:46 2025 kern.warn kernel: [ 56.276218] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:90:a8:22:15:e1:ee
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.286250] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 90:a8:22:15:e1:ee
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.295578] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.304686] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.310718] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.430194] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.436820] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.443586] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 00:54:46 2025 kern.notice kernel: [ 56.450215] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 00:54:46 2025 kern.warn kernel: [ 56.461742] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=2 from 90:a8:22:15:e1:ee
Wed May 14 00:54:47 2025 daemon.err usbmuxd[12431]: [00:54:47.745][3] Caught signal 15, exiting
Wed May 14 00:54:47 2025 daemon.err usbmuxd[12431]: [00:54:47.745][3] usbmuxd shutting down
Wed May 14 00:54:47 2025 daemon.err usbmuxd[12431]: [00:54:47.845][3] Shutdown complete
Wed May 14 00:54:47 2025 daemon.notice netifd: Interface 'modem_0001' is setting up now
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12572): Failed to parse message data
Wed May 14 00:54:48 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 00:54:48 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12572): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:621] QConnectManager_Linux_V1.6.3.1
Wed May 14 00:54:48 2025 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Wed May 14 00:54:48 2025 kern.err kernel: [ 58.146529] [I][mhi_netdev_open] Opened net dev interface
Wed May 14 00:54:48 2025 daemon.notice netifd: Interface 'modem_0001' is now up
Wed May 14 00:54:48 2025 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Wed May 14 00:54:48 2025 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Wed May 14 00:54:48 2025 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Wed May 14 00:54:48 2025 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:622] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:622] network interface '' or qmidev '' is not exist
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:622] netcard driver = pcie_mhi, driver version = V1.3.4
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:622] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:622] Modem works in QMI mode
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:630] cdc_wdm_fd = 7
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:648] Get clientWDS = 15
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:653] Get clientWDS = 16
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:656] Get clientDMS = 1
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:659] Get clientNAS = 3
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:663] Get clientUIM = 2
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:666] Get clientWDA = 1
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:670] requestBaseBandVersion RM520NGLAAR03A03M4G
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:673] qmap_settings.rx_urb_size = 15360
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:674] qmap_settings.ul_data_aggregation_max_datagrams = 11
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:674] qmap_settings.ul_data_aggregation_max_size = 8192
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:674] qmap_settings.dl_minimum_padding = 0
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: started, v1.33.2
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: sending discover
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: sending select for 192.0.0.2
Wed May 14 00:54:48 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: lease of 192.0.0.2 obtained, lease time 7200
Wed May 14 00:54:48 2025 daemon.notice netifd: Interface 'modem_0001_4' is now up
Wed May 14 00:54:49 2025 user.notice kmwan: config json str={ "op": 1, "data": { } }
Wed May 14 00:54:49 2025 kern.debug kernel: [ 59.361494] kmwan: All nodes are deleted.
Wed May 14 00:54:49 2025 user.notice kmwan: config json str={ "op": 0, "data": { "sensitivity": 3000, "mode": "failover" } }
Wed May 14 00:54:49 2025 kern.debug kernel: [ 59.375401] kmwan: sensitivity and mode are set.
Wed May 14 00:54:49 2025 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "modem_0001", "netdev": "rmnet_mhi0", "track_mode": "passive", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Wed May 14 00:54:49 2025 kern.debug kernel: [ 59.461888] [add_dev_config 307]add node success. iface:modem_0001, dev:rmnet_mhi0, ifindex:5
Wed May 14 00:54:50 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Wed May 14 00:54:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 90:a8:22:15:e1:ee
Wed May 14 00:54:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.152 90:a8:22:15:e1:ee
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain test
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain onion
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain localhost
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain invalid
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain bind
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain lan
Wed May 14 00:54:50 2025 daemon.info dnsmasq[6290]: using nameserver 192.0.0.30#53
Wed May 14 00:54:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.152 90:a8:22:15:e1:ee
Wed May 14 00:54:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.152 90:a8:22:15:e1:ee amazon-e6e336e83
Wed May 14 00:54:50 2025 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "modem_0001", "netdev": "rmnet_mhi0", "track_mode": "passive", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Wed May 14 00:54:50 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Wed May 14 06:46:06 2025 user.notice root: modem_traffic : ntp success...
Wed May 14 06:46:10 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 06:46:10 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 06:46:15 2025 cron.err crond[5791]: time disparity of 352 minutes detected
Wed May 14 06:46:17 2025 daemon.err gl_ble_daemon: (ble_manage.c:52) gl_ble_init failed: 1
Wed May 14 06:46:17 2025 daemon.err gl_ble_daemon: (main.c:50) ble initial fail!
Wed May 14 06:46:17 2025 daemon.info procd: Instance gl-ble-daemon::gl_ble_daemon s in a crash loop 6 crashes, 2 seconds since last crash
Wed May 14 06:46:24 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:46:24 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:46:24 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:46:24 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.167 28:57:67:c4:b8:0a Joey-MoCA
Wed May 14 06:46:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:46:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:46:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:46:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1 Joey-MoCA
Wed May 14 06:46:40 2025 daemon.info gl-repeater[3307]: (repeater.lua:1197) ntp been valid
Wed May 14 06:46:44 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:46:44 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:46:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 04:c9:d9:91:d2:ff
Wed May 14 06:46:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:46:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:46:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff Hopper3-br
Wed May 14 06:46:52 2025 kern.debug kernel: [ 107.043292] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed May 14 06:46:52 2025 kern.warn kernel: [ 107.050364] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:7a:ff:4d:33:12:89
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.059062] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 7a:ff:4d:33:12:89
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.068413] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.077524] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.083574] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.206379] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.220570] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.227388] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 06:46:52 2025 kern.notice kernel: [ 107.240636] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 06:46:52 2025 kern.warn kernel: [ 107.252219] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 7a:ff:4d:33:12:89
Wed May 14 06:46:55 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:46:55 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:46:58 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 7a:ff:4d:33:12:89
Wed May 14 06:46:58 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.192 7a:ff:4d:33:12:89
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 7a:ff:4d:33:12:89
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.192 7a:ff:4d:33:12:89
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.192 7a:ff:4d:33:12:89
Wed May 14 06:47:02 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.192 7a:ff:4d:33:12:89 Jeffrey-s-S21-Ultra
Wed May 14 06:47:21 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:47:21 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:47:33 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:47:33 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:47:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:47:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:47:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:47:36 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:47:45 2025 kern.debug kernel: [ 159.879656] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Wed May 14 06:47:45 2025 kern.warn kernel: [ 159.886722] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:1e:e9:ba:fc:58:81
Wed May 14 06:47:45 2025 kern.notice kernel: [ 159.897037] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 1e:e9:ba:fc:58:81
Wed May 14 06:47:45 2025 kern.notice kernel: [ 159.906385] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 06:47:45 2025 kern.notice kernel: [ 159.915515] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed May 14 06:47:45 2025 kern.notice kernel: [ 159.921562] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed May 14 06:47:45 2025 kern.notice kernel: [ 160.042155] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 06:47:45 2025 kern.notice kernel: [ 160.058356] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 06:47:45 2025 kern.notice kernel: [ 160.065114] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 06:47:45 2025 kern.notice kernel: [ 160.083961] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 06:47:45 2025 kern.warn kernel: [ 160.095508] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from 1e:e9:ba:fc:58:81
Wed May 14 06:47:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 1e:e9:ba:fc:58:81
Wed May 14 06:47:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.174 1e:e9:ba:fc:58:81
Wed May 14 06:47:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.174 1e:e9:ba:fc:58:81
Wed May 14 06:47:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.174 1e:e9:ba:fc:58:81 Marti-s-S21-Ultra
Wed May 14 06:47:59 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:47:59 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:48:06 2025 kern.debug kernel: [ 181.506801] entrytb_aid_aquire(): found non-occupied aid:8, allocated from:4
Wed May 14 06:48:06 2025 kern.warn kernel: [ 181.513862] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:50:14:79:54:d3:07
Wed May 14 06:48:06 2025 kern.notice kernel: [ 181.522937] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 50:14:79:54:d3:07
Wed May 14 06:48:06 2025 kern.notice kernel: [ 181.532439] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 06:48:06 2025 kern.notice kernel: [ 181.541542] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed May 14 06:48:07 2025 kern.notice kernel: [ 181.547636] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed May 14 06:48:07 2025 kern.notice kernel: [ 181.667288] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 06:48:07 2025 kern.notice kernel: [ 181.673918] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 06:48:07 2025 kern.notice kernel: [ 181.680681] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 06:48:07 2025 kern.notice kernel: [ 181.687321] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 06:48:07 2025 kern.warn kernel: [ 181.699128] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=5 from 50:14:79:54:d3:07
Wed May 14 06:48:09 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:48:09 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:48:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:48:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:48:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:48:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:48:35 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:48:35 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:48:46 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:48:46 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:48:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:48:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:48:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:48:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:49:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:49:12 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:49:23 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:49:23 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:49:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:49:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:49:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:49:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:49:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:49:49 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:50:00 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:50:00 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:50:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:50:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:50:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:50:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:50:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:50:26 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:50:37 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:50:37 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:50:40 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:50:40 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:50:40 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:50:40 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:51:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:51:03 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:51:14 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:51:14 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:51:17 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:51:17 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:51:17 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:51:17 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:54:38 2025 kern.debug kernel: [ 572.743873] entrytb_aid_aquire(): found non-occupied aid:9, allocated from:4
Wed May 14 06:54:38 2025 kern.warn kernel: [ 572.750943] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:44:bb:3b:43:81:d1
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.758934] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 44:bb:3b:43:81:d1
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.768259] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.777359] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.783393] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.903586] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.933810] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.940565] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 06:54:38 2025 kern.notice kernel: [ 572.947709] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 06:54:38 2025 kern.warn kernel: [ 572.959255] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=6 from 44:bb:3b:43:81:d1
Wed May 14 06:54:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 44:bb:3b:43:81:d1
Wed May 14 06:54:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.221 44:bb:3b:43:81:d1
Wed May 14 06:54:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.221 44:bb:3b:43:81:d1
Wed May 14 06:54:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.221 44:bb:3b:43:81:d1 09AC01AJ09230231
Wed May 14 06:55:36 2025 kern.debug kernel: [ 630.514813] entrytb_aid_aquire(): found non-occupied aid:10, allocated from:4
Wed May 14 06:55:36 2025 kern.warn kernel: [ 630.521959] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:00:45:e2:77:b9:35
Wed May 14 06:55:36 2025 kern.notice kernel: [ 630.530333] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 00:45:e2:77:b9:35
Wed May 14 06:55:36 2025 kern.notice kernel: [ 630.539676] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=0)...
Wed May 14 06:55:36 2025 kern.notice kernel: [ 630.549126] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed May 14 06:55:36 2025 kern.notice kernel: [ 630.555156] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed May 14 06:55:36 2025 kern.warn kernel: [ 630.574090] 7981@C08L2,ap_peer_disassoc_action() 3645: ASSOC - 1 receive DIS-ASSOC request
Wed May 14 06:55:36 2025 kern.warn kernel: [ 630.582371] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed May 14 06:55:36 2025 kern.notice kernel: [ 630.588548] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed May 14 06:55:36 2025 kern.warn kernel: [ 630.595627] 7981@C13L2,MacTableDeleteEntry() 1938: Del Sta:00:45:e
Wed May 14 06:55:40 2025 kern.debug kernel: [ 635.223846] entrytb_aid_aquire(): found non-occupied aid:10, allocated from:4
Wed May 14 06:55:40 2025 kern.warn kernel: [ 635.230994] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:00:45:e2:77:b9:35
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.239219] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 00:45:e2:77:b9:35
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.248556] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=0)...
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.257999] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.264033] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.392165] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.421190] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.427946] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed May 14 06:55:40 2025 kern.notice kernel: [ 635.434574] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed May 14 06:55:41 2025 kern.warn kernel: [ 635.446109] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=7 from 00:45:e2:77:b9:35
Wed May 14 06:55:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPREQUEST(br-lan) 192.168.8.116 00:45:e2:77:b9:35
Wed May 14 06:55:41 2025 daemon.info dnsmasq-dhcp[6290]: DHCPACK(br-lan) 192.168.8.116 00:45:e2:77:b9:35 LAPTOP-HHUA99RD
Wed May 14 06:56:37 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 06:56:37 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 06:56:47 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:56:47 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:56:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 06:56:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 06:56:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 06:56:50 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 06:57:23 2025 daemon.err modem_AT: (modem_AT.c:155) AT_Read@155 The number of times the epoll reached timeout:8
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: received SIGTERM
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: unicasting a release of 192.0.0.2 to 192.0.0.1
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: sending release
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001_4 (12929): udhcpc: entering released state
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001_4 (12929): Command failed: Permission denied
Wed May 14 06:57:23 2025 daemon.notice netifd: Interface 'modem_0001_4' is now down
Wed May 14 06:57:23 2025 daemon.notice netifd: Network alias '' link is down
Wed May 14 06:57:23 2025 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity loss
Wed May 14 06:57:23 2025 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Wed May 14 06:57:23 2025 daemon.warn dnsmasq[6290]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Wed May 14 06:57:23 2025 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Wed May 14 06:57:23 2025 kern.info kernel: [ 737.919244] net rmnet_mhi0: link_state 0x1 -> 0x0
Wed May 14 06:57:23 2025 daemon.notice netifd: Network device 'rmnet_mhi0' link is down
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:695] requestGetSIMStatus SIMStatus: SIM_READY
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:698] requestGetProfile[1] fast.t-mobile.com///0/IPV4V6
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:698] requestSetProfile[1] fast.t-mobile.com///0/IPV4V6
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:698] no need to set skip the rest
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:701] requestRegistrationState2 MCC: 310, MNC: 260, PS: Attached, DataCap: 5G_SA
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:704] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:707] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:782] requestSetupDataCall WdsConnectionIPv4Handle: 0xe29726a0
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:787] trying to get ipv6 address
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_00:54:48:797] requestSetupDataCall WdsConnectionIPv6Handle: 0xe2667480
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_06:57:23:523] requestDeactivateDefaultPDP WdsConnectionIPv4Handle
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_06:57:23:531] requestDeactivateDefaultPDP WdsConnectionIPv6Handle
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_06:57:23:559] QmiWwanThread exit
Wed May 14 06:57:23 2025 daemon.notice netifd: modem_0001 (12882): [05-14_06:57:23:559] qmi_main exit
Wed May 14 06:57:23 2025 daemon.notice netifd: Interface 'modem_0001' is now down
Wed May 14 06:57:23 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_0001" ] } }
Wed May 14 06:57:23 2025 kern.debug kernel: [ 738.251314] kmwan: Delete node:modem_0001
Wed May 14 06:57:24 2025 daemon.notice netifd: Interface 'modem_0001' is setting up now
Wed May 14 06:57:31 2025 daemon.err modem_AT: (modem_AT.c:155) AT_Read@155 The number of times the epoll reached timeout:8
Wed May 14 06:57:31 2025 daemon.notice netifd: modem_0001 (24266): Failed to parse message data
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24266): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:157] QConnectManager_Linux_V1.6.3.1
Wed May 14 06:57:32 2025 daemon.notice netifd: Interface 'modem_0001' is now up
Wed May 14 06:57:32 2025 kern.err kernel: [ 746.582363] [I][mhi_netdev_open] Opened net dev interface
Wed May 14 06:57:32 2025 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:158] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:159] network interface '' or qmidev '' is not exist
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:159] netcard driver = pcie_mhi, driver version = V1.3.4
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:159] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:159] Modem works in QMI mode
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:171] cdc_wdm_fd = 7
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:180] Get clientWDS = 15
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:182] Get clientWDS = 16
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:184] Get clientDMS = 1
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:186] Get clientNAS = 3
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:188] Get clientUIM = 2
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:191] Get clientWDA = 1
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:193] requestBaseBandVersion RM520NGLAAR03A03M4G
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:196] qmap_settings.rx_urb_size = 15360
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:196] qmap_settings.ul_data_aggregation_max_datagrams = 11
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:196] qmap_settings.ul_data_aggregation_max_size = 8192
Wed May 14 06:57:32 2025 daemon.notice netifd: modem_0001 (24835): [05-14_06:57:32:196] qmap_settings.dl_minimum_padding = 0
Wed May 14 06:57:33 2025 user.notice kmwan: config json str={ "op": 1, "data": { } }
Wed May 14 06:57:33 2025 kern.debug kernel: [ 747.774559] kmwan: All nodes are deleted.
Wed May 14 06:57:33 2025 user.notice kmwan: config json str={ "op": 0, "data": { "sensitivity": 3000, "mode": "failover" } }
Wed May 14 06:57:33 2025 kern.debug kernel: [ 747.791320] kmwan: sensitivity and mode are set.
Wed May 14 06:57:33 2025 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "modem_0001", "netdev": "rmnet_mhi0", "track_mode": "passive", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Wed May 14 06:57:33 2025 kern.debug kernel: [ 747.870102] [add_dev_config 307]add node success. iface:modem_0001, dev:rmnet_mhi0, ifindex:5
Wed May 14 06:57:33 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Wed May 14 06:57:35 2025 kern.info kernel: [ 749.719746] net rmnet_mhi0: link_state 0x0 -> 0x1
Wed May 14 06:57:35 2025 kern.info kernel: [ 749.724971] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Wed May 14 06:57:35 2025 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Wed May 14 06:57:35 2025 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Wed May 14 06:57:35 2025 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Wed May 14 06:57:35 2025 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Wed May 14 06:57:35 2025 daemon.notice netifd: modem_0001_4 (25383): udhcpc: started, v1.33.2
Wed May 14 06:57:35 2025 daemon.notice netifd: modem_0001_4 (25383): udhcpc: sending discover
Wed May 14 06:57:35 2025 daemon.notice netifd: modem_0001_4 (25383): udhcpc: sending select for 192.0.0.2
Wed May 14 06:57:35 2025 daemon.notice netifd: modem_0001_4 (25383): udhcpc: lease of 192.0.0.2 obtained, lease time 7200
Wed May 14 06:57:35 2025 daemon.notice netifd: Interface 'modem_0001_4' is now up
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain test
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain onion
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain localhost
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain invalid
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain bind
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using only locally-known addresses for domain lan
Wed May 14 06:57:35 2025 daemon.info dnsmasq[6290]: using nameserver 192.0.0.30#53
Wed May 14 06:57:35 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Wed May 14 07:06:28 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 07:06:28 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 07:06:39 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 07:06:39 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 07:06:42 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 07:06:42 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 07:06:42 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 07:06:42 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 07:16:20 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.124 04:c9:d9:8a:2d:a1
Wed May 14 07:16:20 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.125 04:c9:d9:8a:2d:a1
Wed May 14 07:16:31 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 07:16:31 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Wed May 14 07:16:34 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.188 04:c9:d9:91:d2:ff
Wed May 14 07:16:34 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.189 04:c9:d9:91:d2:ff
Wed May 14 07:16:34 2025 daemon.info dnsmasq-dhcp[6290]: DHCPDISCOVER(br-lan) 192.168.8.167 28:57:67:c4:b8:0a
Wed May 14 07:16:34 2025 daemon.info dnsmasq-dhcp[6290]: DHCPOFFER(br-lan) 192.168.8.166 28:57:67:c4:b8:0a
Thanks for the support.
Hi, the log shows that router lost cellular network on May 14th 6:57 and then automatically reconnected and restored the network. Is it possible to share your device with GL.iNet via Goodcloud (see link below) for analysis:
If you have other networks, such as repeater internet or wired internet, please connect router to it as network backup. We would like to remotely access the device to investigate the issue when the cellular network drops. Thanks
The internet was on in the morning of the 14th. At 6:57 the internet dropped and I unplugged and replugged the router. This morning the 15th, is the first morning in quite sometime that I woke up and the internet was still on. I don't have repeater internet or wired internet. Thanks
Understood. Is it possible to share your device with GL.iNet for remote troubelshooting? We would like to get some modem log for analysis?
I don't know what is possible? I am asking you what and how to fix this. I wake up every morning looking for your response and it's a bunck of stuff I don't understand. What do you mean by these comments? "Is it possible to share your device with GL.iNet for remote troubelshooting? We would like to get some modem log for analysis?"
I am unsure how to share my device with GL.inet for remote trouble shooting. I am more than willing to do so but don't know the steps to do so. Thanks
The tech support already shared with you how you can share your device for remote troubleshooting in this thread with good cloud.
I am unable to setup a good cloud account because it is asking for a email verification code of which I I don't have. Usually you setup your account and then a verification code is provided. To create the Good Cloud account it asks for User Name, Password, Confirm Password, Email, Email Certification Code, and then Send. Where do I ge the Certification code?
You might need to create a GoodCloud account and bind your device to your account first.
  1. Go to GoodCloud and log in or sign up for an account.
  2. Bind your device to GoodCloud. Refer to Add Device.
You need to sigup and if your email is not getting verfication, check spam or use another email. hotmail is notorious swallow legitimate email (and not even show up as spam).
BTW, what is your Modem SIM card APN setting, for TMHI, APN shall be set to fast.metropcs.com (unlike using SIM in TMOBILE phone, where the APN is fast.t-mobile.com).
But diplomatically speaking, using phone SIM on TMHI breaks the tmobile term. Maybe you shall leave the APN as phone setting in the modem to avoid being banned by TMOBILE (but unsure if will cause issue you are experiencing)
I don't have a TMHI SIM card. I have a T Mobile Magenta Phone/data Sim card. I can't find where the APN setting is on the Admin Panel. Thanks for the help.
When I try to log into LuCi, it shows user name: root and it wants a password. I don't know the password.
I was able to create an account for good cloud via the link you sent. The layout and look of good cloud you sent with the link is different than via the x3000 router. I am log into good cloud with your link but am unable to log into good cloud via the router admin panel. I will not except the password.
As mentioned earlier, I have a tmobile phone/data sim card that I have been using for about 5 years and at least two years via the x3000 router. I would think because it works for a short while before it drops, it has nothing to do with t-mobile and has more to do with a router setting. If it was tmobile I would thing it would not work at all.
Luci password is the same as you admin panel login one.
As to "I can't find where the APN setting is on the Admin Panel." it is right on the admin panel front page. Since this is about SIM card, look at SIM card settings ........ > . click the > sign.
I think I made it clear, TMOBILE term does not allow using for SIM card for home internet use. You tweak it at your own risk.
