I have an GL-X3000 using a Vodafone (Greece) SIM. It working very well: high throughput; connection stays up; reconnects quickly on the few occasions it needs to.
However the modem device is consistently reporting ~3 RX errors per second (see below). This is not affected by traffic (ie. does not go up with more traffic or drop when connection is idle).
Does this point to a “real” problem? If it’s OK to ignore the errors, can I prevent them being collected and/or reported?
Thanks
Sean
# ifconfig ra0
ra0 Link encap:Ethernet HWaddr 94:83:C4:32:28:80
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:20989373 errors:8180989 dropped:0 overruns:0 frame:0
TX packets:4710979 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:548797859 (523.3 MiB) TX bytes:417782448 (398.4 MiB)
Interrupt:7
