The GL-X3000 is very, VERY fast on 5G (I’ve seen 445 Mps down; 90 Mbps up) and seems to be stable and reliable.
On the GL-X750 it was possible to use uqmi to retrieve connection status, RSSI, etc, shell scripts could stop and start the network connection, and as a last resort a hard restart of modem was possible by toggling a gpio.
As far as I can see the GL-X3000 doesn’t use qmi to communicate with the modem, so no uqmi.
Is there an alternative to uqmi to get status, RSSI, RSRQ etc. within scripts rather than the HTML console? And is there a recommended way of re-starting connection, resetting modem, etc. ?
Cheers
Sen
lizh
August 9, 2023, 3:39am
2
Nerdvana:
AT present, the basic information of some modem can be obtained by AT instruction.
Can you be more specific about what information you want?
I’m happy to use AT commands, if that will not interfere with system software. To device ‘/dev/mhi_DUN’ I guess?
Here are the three uqmi commands that I think are most useful (on a GL-X750):
root@2HHG-4G:~# uqmi -d /dev/cdc-wdm0 --get-data-status
"connected"
root@2HHG-4G:~# uqmi -d /dev/cdc-wdm0 --get-signal-info
"type": "lte",
"rssi": -48,
"rsrq": -10,
"rsrp": -75,
"snr": 114
root@2HHG-4G:~# uqmi -d /dev/cdc-wdm0 --get-current-settings
"pdp-type": "ipv4",
"ip-family": "ipv4",
"mtu": 1500,
"ipv4": {
"ip": "10.34.236.123",
"dns1": "10.205.64.1",
"dns2": "10.205.64.1",
"gateway": "10.34.236.124",
"subnet": "255.255.255.248"
"ipv6": {
"domain-names": {
DX3000
September 6, 2024, 2:50pm
5
signal: AT+QRSRP
Which signal is this suppose to display?
I would like to see my RSSI.
When I input the command it Returns "OK".
admon
September 6, 2024, 2:52pm
6
AT+CSQ should be the command to get the RSSI
admon
September 6, 2024, 3:06pm
8
This is the table for translating the values:
Value
RSSI dBm
Condition
99
Feature not implemented
2
-109
Marginal
3
-107
Marginal
4
-105
Marginal
5
-103
Marginal
6
-101
Marginal
7
-99
Marginal
8
-97
Marginal
9
-95
Marginal
10
-93
OK
11
-91
OK
12
-89
OK
13
-87
OK
14
-85
OK
15
-83
Good
16
-81
Good
17
-79
Good
18
-77
Good
19
-75
Good
20
-73
Excellent
21
-71
Excellent
22
-69
Excellent
23
-67
Excellent
24
-65
Excellent
25
-63
Excellent
26
-61
Excellent
27
-59
Excellent
28
-57
Excellent
29
-55
Excellent
30
-53
Excellent
DX3000
September 6, 2024, 3:07pm
9
Why isn't RSSI displayed in the Historical Signal Strength tab?
DX3000
September 7, 2024, 7:07am
11
Yes.
That's the only cellular signal I can get at this location.
The closest tower is approximately 23 miles away.
DX3000
September 7, 2024, 1:08pm
14
Could this be the reason why no cell towers are found ?
misuzu
September 8, 2024, 1:15am
15
Probably yes since AT+QSCAN is only applicable for LTE and 5G I believe
