GL-X3000 on Omada
I currently use a TP-link OC200 controller (Omada), ER605 gateway, switch and various APs at home.
I want to replace the Virginmedia modem (bridge mode) and ER605 gateway, replacing them with the GL-X3000. I have tried to directly replace the gateway, add the X3000 to the second WAN on the ER605 and connect the X3000 directly to the controller but nothing works. Are there any guides or advice? Searched google and nothing really available to help.
Thanks
How are you expecting the tplink omada controller to adopt a GL inet router?
I’m not necessarily expecting it to adopt the X3000 or to use the controller/router at all. I am just unsure how this router will work with the switch and APs I have. I can connect to the X3000 router directly with a laptop no issues and have internet. If I add in the X3000 router to my setup it shows the switch and APa as connected to it but no internet. Do I just reset all other devices and set up each item individually? Tried so much and just want to get it to work but not sure how.
