gl-x3000 ping is is slower do not use wifi use the lan port that connect tc opnsense then go to 2 router. I thought gl x3000 is supposed ping faster then stock tmoble modem I am use gl-x3000 firmware version 4.8.3
is there any way I can improve the ping time
- Your tests are using different servers. You can’t expect them to be similar. Next time you do these tests, make sure you use the Ookla “select nearest server” option and select the same server for each test.
- Use the Hint tool to collect specific information from the TMO gateway about which tower you’re connecting to. If the TMO gateway uses a different tower than the Spitz does, you’ll be making apples-to-alligators comparisons.
- what changes have you made to the default Spitz configuration?
I turned off Wi-Fi and I turned off accelerator and lock the modem to channel 41 that Channel my T-Mobile modem use and mtu 1500 apn fbb.home
OK, @saki22, what about #1 & #2?
I figured it out I was using the wrong cell tower and I changed my MTU value the ping to the servers much faster thank you I was trying to match the same settings I'm a T-Mobile router and I totally forgot about the cell tower
