GL-X3000(Spitz AX) disassembling/board diagram/UART pins
Hi folks,
Today I opened the case of my GL-X3000 to find how I can connect my USB-UART cable. Because I do not want to damage it, I decided to pause and take suggestions form you!
  • Has anyone disassembled the same device? Can you share your experience?
  • Is there a a clear diagram for the board?
  • Can GL engineers share the latest Uboot for this device as I could not find it in the GitHub repos?
May we know the purpose of your dismantling and use the UBoot?
Yes, because I want to know how to connect my usb uart cable without damaging the device.
I am planning to compile my own uboot and stock firmware (without gl packages) then flash it to the device.
Sorry, I didn’t make it clear.
What we want to know is whether you are using it for commercial use or personal DIY.
For personal use…………
I tried to use the UART pins in order to connect a USB-UART cable, following the pinout I found here:
However I don’t see any output on the UART port, either from U-Boot or the firmware. I’ve tried using several USB-UART cables, changed all the UART settings I could think of (and used the ones listed here), but to no avail.
Is there a setting to change in the U-Boot (version U-Boot 2022.07-rc3 (Mar 09 2023 - 16:20:34 +0800)) or the firmware (version 4.3.5) in order to enable the UART port?
Hopefully someone from GL can help as I posted this post several months ago.
@dohseven please keep us posted with your progress as I want also to use usb-uart cable to modify the Uboot and install custom openwrt firmware.
Uart is enabled by default.Please check tx and rx.And do not connect the power pin.
I try to fix a bricked GL-X3000 (Spitz AX). No LED & LAN when powering on.
UART is showing this when powering on:
F0: 102B 0000
FA: 1040 0000
FA: 1040 0000 [0200]
F9: 103F 0000
F3: 1006 0033 [0200]
F3: 4001 00E0 [0200]
F3: 4002 0000
F6: 102C 0000
F5: 1026 0000
00: 1005 0000
FA: 1040 0000
F9: 103F 0000
F3: 4002 0000
F6: 102C 0000
01: 102A 0001
02: 1005 0000
BP: 2000 00C0 [0001]
EC: 0000 0000 [2000]
T0: 0000 00BE [010F]
System halt!
I tried mtk_uartboot with no sucess:
mtk_uartboot.exe -s COM7 -a -p openwrt-x3000-preloader.bin -f openwrt-bl31-uboot.fip
mtk_uartboot - 0.1.1
Using serial port: COM7
Handshake... -> no change.
What recovery methods are possible?
  1. USB-A <-> USB-A cable?
  2. mtk uartboot?
  3. other?
i can confirm, that mtk_uartboot is working with the right timing (starting pgm / powering on):
mtk_uartboot.exe -s COM7 -a -p bl2-mt7981-bga-ddr4-ram.bin -f openwrt-mediatek-filogic-glinet_gl-x3000-bl31-uboot.fip && putty.exe -serial COM7 -sercfg 115200,8,n,1,N
Handshake...
hw code: 0x7981
hw sub code: 0x8a00
hw ver: 0xca00
sw ver: 0x1
Baud rate set to 460800
sending payload to 0x201000...
Checksum: 0x6f0e
Setting baudrate back to 115200
Jumping to 0x201000 in aarch64...
Waiting for BL2. Message below:
NOTICE:  BL2: v2.10.0   (release):v2.10.0-mtk
NOTICE:  BL2: Built : 13:17:08, Mar  1 2024
NOTICE:  WDT: Cold boot
NOTICE:  WDT: disabled
NOTICE:  EMI: Using DDR4 settings
NOTICE:  EMI: Detected DRAM size: 512MB
NOTICE:  EMI: complex R/W mem test passed
NOTICE:  CPU: MT7981 (1300MHz)
NOTICE:  Starting UART download handshake ...
BL2 UART DL version: 0x10
Baudrate set to: 921600
FIP sent.
NOTICE:  Received FIP 0x817b1 @ 0x40400000 ...
it was not possible to flash gl inet stock uboot directly. I did it this way once system booted:
echo 0 >/sys/block/mmcblk0boot0/force_ro
dd if=X3000_uboot_fip.bin of=/dev/mmcblk0p4
dd if=X3000_bl2.img of=/dev/mmcblk0boot0
@asgdfgfew23 Here are the details you requested:
  1. RM520N-GL has ANT1 for GNSS L5 and ANT3 for GNSS L1, how is this mapped to the SMA ports on X3000? I guss DIV / GNSS is ANT3, which SMA port is for GNS
The "DIV/GNSS" port is indeed ANT3. The correspondence between other antennas and ports is shown in the diagram below.
  1. btw is the PCB diagram GL-X3000(Spitz AX) disassembling/board diagram/UART pins - #6 by dohseven here correct? only 3 antenna leads shown
The WiFi uses 3 antennas in total: 2 external dual-band antennas (supporting 2.4GHz & 5GHz) and 1 internal 5GHz antenna.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
