GL-X3000 (Spitz AX) does not boot after power loss — needs multiple plug cycles (camper use)
Hi everyone,
I’m using the GL-X3000 (Spitz AX) in my camper with the original 230V power adapter, and I’m having serious issues with booting after power loss.
What’s happening:
  • When I cut power (to save energy during winter) and later turn it back on, the router often does not boot correctly.
  • Sometimes only the power LED is on, and nothing else happens.
  • Other times the 2.4G LED blinks, but:
    • No Wi-Fi network shows up.
    • I can’t reach the UI at 192.168.8.1.
  • I then have to unplug and replug the power adapter 2–4 times before it boots normally.
  • Once it boots, it works fine. The issue is only with cold boots after power loss.
  • I’m only using 2.4 GHz Wi-Fi.
How I use it:
  • In summer, I have constant power and everything works great.
  • In winter, I turn off power 1–2 times per day to save energy in the camper.
  • Every time power returns, I have this boot issue.
What I tried:
  • Using the original GL.iNet adapter.
  • Checked all cables and power delivery, all solid.
  • Updated firmware to v4.8.3, but in the interface it still shows v4.0 (??).
  • Did a full factory reset.
  • Problem still exists.
My questions:
  1. Is this a known bug in Spitz AX?
  2. Could this be firmware related (e.g. stuck during boot)?
  3. Is there a way to make it boot more reliably after power loss?
  4. Any boot logs or debug mode I can access?
This is really frustrating in daily use, I’d love to keep using the Spitz AX, but this issue makes it hard to rely on.
Thanks in advance!
Lex
We are very sorry for the inconvenience this has caused.
Let the router into uboot mode (how-to?), flash the latest firmware, to see if there is any improvement?
If no luck, please contact our CS team at [email protected], cite this thread, and provide the purchase record.
Hi Bruce, thanks for your reply.
I’ll try to avoid a full reset for now if possible, I’ve already done a full factory reset recently and it didn’t help, so flashing via U-Boot feels a like a hassle unless really necessary.
I’ve read in a few forums that this issue might be caused by a voltage drop during power-up. Could that be the case with the GL-X3000? And if so, are there any tweaks or safer boot settings I can try to improve cold boot reliability without going through a full reflash?
Would love to avoid resetting everything again, especially since the device works perfectly once it’s running.
Thanks in advance,
Lex
Since you have mentioned in the thread that the original adapteris being used, there should be no problem of the voltage during router plug in the DC cable and power-on.
Flashing firmware with uboot is a necessary operation at now.
If it does not improve the situation, please contact CS team and obtain the after-sales service.
If it can be started under the current situation (although it may take a few more power unplugs and plugs), enter Luci after startup and back up the current configuration.
Might try running it off 12v. If the rv is 24v or something a 24v→12v buck converter would also ensure stable voltage supply.
I had a device like this, and I had to buy a small USB UPS to plug in the back and run the ‘nut’ package and set it to “soft power shutdown” when the mains went out. Turns out the hard power-off was causing it to try and run fsck at boot which then errored out and hung the system. Took several reboot loops to finally bring it back each time.
Alternative is to manually shutdown the system before removing power. This gives you a ‘clean’ shutdown without forcing fsck on boot.
I don’t think a buck converter is needed. The Spitx can accept 9-36V. GL-X3000 Spitz AX input voltage range - #2 by Tim-Zhang
I appreciate the info. If it accepts that wide a range then I wouldn’t think regulating to ~12v would do any good.
I am running the X3000 in my van with 12V and had no issues so far. I just turn it off randomly, so not that often, as you do. Might try this cable: HIEbee for Starlink Mini Kabel 6.6FT Starlink Mini USB C auf DC Netzkabel 100W Eingang USB Typ C auf DC Kabel, DC Netzkabel Direkt auf USB-C für Starlink Mini Arbeiten mit 100W+ PD : Amazon.de: Computer & Zubehör
