GL-X3000 (Spitz AX) will not connect to cellular without intervention
I have a GL-X3000 Spitz AX with a t-mobile sim installed as the only wan.
when I cold boot or reboot, the internet settings page will just sit there saying “connecting…” and never get an connection.
but.
if I simply login, click abort, and click auto, it instantly connects.
I am supposed to be setting this up and shipping it to someone to use as their primary internet connection and having to do that every time the device reboots will not work.
how can I make this thing connect automatically when it boots and not require manual intervention?
I am running 4.3.5 firmware
I deleted the default profile and made a new profile with the settings required for my sim and applied the profile to the sim.
I am having the same issue with t-mobile. I contacted tech support they asked for my log file. If I pull the barrel connector or unplug the a/c power it will automatically reconnect but if I reboot no connection.
You can get the logs by logging in via SSH & logread. They are also available via LuCI’s Status → System Log → [System Log/Kernel Log]. You can install LuCI via GL GUI → System → Advanced Settings. Same password as the GL GUI, the default username is root .
@cTurtle98 @slphelan
I just tested it.It is OK.
Need you to help provide the following log information:
Thanks!
I know I did not start this string but I am having the same problem. I saved my logs to the desktop but I am not able to upload it for this site it asks for hyperlink. How do I do hyperlink for item saved to my computer?
If it helps, these forums support the MarkDown syntax; use three backticks for ‘code fencing’. It’ll improve readability. Eg:
Like this…
to get
this
So it might just be easier to copy & paste the logs.
System Log:
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:693] Modem works in QMI mode
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:832] cdc_wdm_fd = 7
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:913] Get clientWDS = 14
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:922] Get clientWDS = 15
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:927] Get clientDMS = 1
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:936] Get clientNAS = 4
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:938] Get clientUIM = 2
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:941] Get clientWDA = 1
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:945] requestBaseBandVersion RM520NGLAAR01A07M4G
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:948] qmap_settings.rx_urb_size = 15360
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:948] qmap_settings.ul_data_aggregation_max_datagrams = 11
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:948] qmap_settings.ul_data_aggregation_max_size = 8192
Tue Jul 25 19:41:56 2023 daemon.notice netifd: modem_0001 (5251): [07-25_19:41:55:948] qmap_settings.dl_minimum_padding = 0
Tue Jul 25 19:41:56 2023 kern.err kernel: [ 28.150033] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.161388] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.169474] 7981@C18L3,BuildChannelList() 484:
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.174076] 7981@C00L3,BuildChannelList() 514: BandIdx = 1, PhyMode = 177, ChListNum = 21:
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.182578] 7981@C23L3,DfsBuildChannelList() 3715: Done
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.188184] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.197806] 7981@C18L3,BuildChannelList() 484:
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.202453] 7981@C23L3,RadarStateCheck() 244: Zero Wait State: 0
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.208605] 7981@C23L3,RadarStateCheck() 268: e[1;33m RD_SILENCE_MODE e[m
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.215600] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(36), ht_bw(1), extcha(1), vht_bw(2), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.227411] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(3), prim_ch(36), cen_ch_1(50), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.239207] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(3), prim_ch(36), cen_ch_1(50), cen_ch_2(0)!
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.250286] 7981@C23L3,DfsCacNormalStart() 3582: [RDM] CAC 65 seconds start . Disable MAC TX
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.258813] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:56 2023 kern.err kernel: [ 28.265685] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.274893] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=36, ctrl_ch2=0, cent_ch=50 DBDCIdx=1, ChBand=1, BW=3, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.288092] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=36, ctrl_ch2=0, cent_ch=50, RxPath=7, BandIdx=1, ChBand=1, BW=3,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:41:56 2023 kern.err kernel: [ 28.302277] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.313653] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.321780] 7981@C18L3,BuildChannelList() 484:
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.326365] 7981@C00L3,BuildChannelList() 514: BandIdx = 1, PhyMode = 177, ChListNum = 21:
Tue Jul 25 19:41:56 2023 kern.notice kernel: [ 28.334823] 7981@C23L3,DfsBuildChannelList() 3715: Done
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.340439] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.356650] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.366204] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:56 2023 kern.warn kernel: [ 28.374668] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.382942] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(36), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.394708] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(36), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.406503] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(3), prim_ch(36), cen_ch_1(50), cen_ch_2(0)!
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.418093] 7981@C23L3,DfsCacNormalStart() 3582: [RDM] CAC 65 seconds start . Disable MAC TX
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.426712] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 28.433570] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.442830] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=36, ctrl_ch2=0, cent_ch=50 DBDCIdx=1, ChBand=1, BW=3, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.459917] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=36, ctrl_ch2=0, cent_ch=50, RxPath=7, BandIdx=1, ChBand=1, BW=3,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 28.474084] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:57 2023 daemon.err ovpnclient[4461]: RESOLVE: Cannot resolve host address: us-mia.vpnunlimitedapp.com:1194 (Try again)
Tue Jul 25 19:41:57 2023 daemon.warn ovpnclient[4461]: Could not determine IPv4/IPv6 protocol
Tue Jul 25 19:41:57 2023 daemon.notice ovpnclient[4461]: SIGHUP[soft,init_instance] received, process restarting
Tue Jul 25 19:41:57 2023 daemon.warn ovpnclient[4461]: DEPRECATED OPTION: --cipher set to ‘AES-256-CBC’ but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add ‘AES-256-CBC’ to --data-ciphers or change --cipher ‘AES-256-CBC’ to --data-ciphers-fallback ‘AES-256-CBC’ to silence this warning.
Tue Jul 25 19:41:57 2023 daemon.notice ovpnclient[4461]: OpenVPN 2.5.3 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Tue Jul 25 19:41:57 2023 daemon.notice ovpnclient[4461]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Tue Jul 25 19:41:57 2023 kern.warn kernel: [ 28.496388] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:57 2023 kern.warn kernel: [ 28.506906] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:57 2023 kern.warn kernel: [ 28.546973] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:57 2023 kern.debug kernel: [ 28.584747] SetPercentageCtrl: ucBandIdx = 1
Tue Jul 25 19:41:57 2023 kern.debug kernel: [ 28.589046] SetPercentageCtrl: TxPowerPercentEn = 0
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.594595] 7981@C18L3,BuildChannelList() 484:
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.599175] 7981@C00L3,BuildChannelList() 514: BandIdx = 1, PhyMode = 177, ChListNum = 25:
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.607712] 7981@C23L3,DfsBuildChannelList() 3715: Done
Tue Jul 25 19:41:57 2023 daemon.info avahi-daemon[5347]: Server startup complete. Host name is GL-X3000.local. Local service cookie is 2291145368.
Tue Jul 25 19:41:57 2023 kern.debug kernel: [ 28.649817] Set_AutoChannelSel_Proc Alg=3
Tue Jul 25 19:41:57 2023 kern.debug kernel: [ 28.653856] e[42mSet_AutoChannelSel_Proc: Alg = 3 e[m
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.659195] 7981@C23L3,TakeChannelOpCharge() 1109: caller:Set_AutoChannelSel_Proc+0x394/0x450 [mt_wifi]. TakeCharge succeed!
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.659195] 7981@C23L3,AutoChSelBuildChannelListFor56G() 2732: ChListNum56G = 4
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.677896] 7981@C23L3,AutoChSelBuildChannelListFor56G() 2925: ACSChListNum = 4
Tue Jul 25 19:41:57 2023 kern.warn kernel: [ 28.685510] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:33:84:84), Reason 0x10
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.686120] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 28.694407] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Tue Jul 25 19:41:57 2023 kern.warn kernel: [ 28.694809] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (96:83:c4:33:84:84), Reason 0x10
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 28.701220] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 28.707991] 7981@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.732910] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=36, ctrl_ch2=0, cent_ch=36 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 28.761717] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=36, ctrl_ch2=0, cent_ch=36, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jul 25 19:41:57 2023 user.notice mwan3[4379]: Execute ifup event on interface lan (br-lan)
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.012272] 7981@C23L3,AutoChSelScanTimeout() 3331: [AutoChSelScanTimeout] - BandIdx = 1
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.020842] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 29.027721] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.036973] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=40, ctrl_ch2=0, cent_ch=40 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jul 25 19:41:57 2023 daemon.notice procd: /etc/rc.d/S99disk_manage: start app = /usr/bin/disk_manage
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.071820] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=40, ctrl_ch2=0, cent_ch=40, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jul 25 19:41:57 2023 daemon.err odhcpd[4274]: Failed to send to ff02::1%lan@br-lan (Address not available)
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.328264] 7981@C23L3,AutoChSelScanTimeout() 3331: [AutoChSelScanTimeout] - BandIdx = 1
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.338361] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:57 2023 kern.err kernel: [ 29.345206] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:57 2023 kern.notice kernel: [ 29.354413] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=44, ctrl_ch2=0, cent_ch=44 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jul 25 19:41:58 2023 daemon.err gl_ble_daemon: (ble_manage.c:45) gl_ble_init failed: 1
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 29.425848] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=44, ctrl_ch2=0, cent_ch=44, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 29.684253] 7981@C23L3,AutoChSelScanTimeout() 3331: [AutoChSelScanTimeout] - BandIdx = 1
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 29.692795] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:58 2023 kern.err kernel: [ 29.699623] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 29.708811] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=48, ctrl_ch2=0, cent_ch=48 DBDCIdx=1, ChBand=1, BW=0, TXStream=3, RXStream=3, scan(1)
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 29.789777] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=48, ctrl_ch2=0, cent_ch=48, RxPath=7, BandIdx=1, ChBand=1, BW=0,TXStream=3, RXStream=7, scan(1)
Tue Jul 25 19:41:58 2023 kern.debug kernel: [ 29.996244] BcnCheck start after 2100 ms (ra0)
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.028253] 7981@C23L3,AutoChSelScanTimeout() 3331: [AutoChSelScanTimeout] - BandIdx = 1
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.036800] 7981@C23L3,SelectClearChannelBusyTime() 1880: ====================================================================
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.048329] 7981@C23L3,SelectClearChannelBusyTime() 1886: Channel 36 : Busy Time = 138, Skip Channel = FALSE, BwCap = TRUE
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.059802] 7981@C23L3,SelectClearChannelBusyTime() 1886: Channel 40 : Busy Time = 104, Skip Channel = FALSE, BwCap = TRUE
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.071262] 7981@C23L3,SelectClearChannelBusyTime() 1886: Channel 44 : Busy Time = 0, Skip Channel = FALSE, BwCap = TRUE
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.082717] 7981@C23L3,SelectClearChannelBusyTime() 1886: Channel 48 : Busy Time = 304, Skip Channel = FALSE, BwCap = TRUE
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.094134] 7981@C23L3,SelectClearChannelBusyTime() 1889: ====================================================================
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.105622] 7981@C23L3,SelectClearChannelBusyTime() 2125: Rule 3 Channel Busy time value : Select Primary Channel 44
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.116180] 7981@C23L3,SelectClearChannelBusyTime() 2127: Rule 3 Channel Busy time value : Min Channel Busy = 304
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.126510] 7981@C23L3,SelectClearChannelBusyTime() 2132: Rule 3 Channel Busy time value : BW = 80
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.135544] 7981@C23L3,SelectClearChannelBusyTime() 2166: [SelectClearChannelBusyTime] - band1 END
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.144524] 7981@C23L3,AutoChSelScanNextChannel() 3107: Current channel = 36 , selected new channel = 44
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.154012] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(36), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.165754] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(36), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.177440] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(36), cen_ch_1(42), cen_ch_2(0)!
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.188552] 7981@C23L3,DfsCacNormalStart() 3582: [RDM] CAC 65 seconds start . Disable MAC TX
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.197065] 7981@C23L3,DfsSwitchCheck() 3871: DFS ByPass TX calibration.
Tue Jul 25 19:41:58 2023 kern.err kernel: [ 30.203925] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.213130] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=36, ctrl_ch2=0, cent_ch=42 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:41:58 2023 kern.notice kernel: [ 30.306793] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=36, ctrl_ch2=0, cent_ch=42, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 30.348185] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.359292] 7981@C23L3,scan_ch_restore() 252: End of SCAN(TYPE: 0, BandIdx: 1), restore to BW(2) channel 42, Total BSS[02]
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.370421] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.378784] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 78
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.385818] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.394268] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 78
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.401555] 7981@C23L3,rtmp_set_channel() 2815: (caller:AutoChSelScanNextChannel+0x260/0xd28 [mt_wifi]), Channel(44), quick_ch_change:1.
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.414129] 7981@C23L3,perform_channel_change() 2510: (caller:rtmp_set_channel+0x270/0x538 [mt_wifi]), Channel(44), quick_ch_change:1.
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.426239] 7981@C08L3,perform_channel_change() 2612: [RDM]e[1;33m Silence Mode–>> Switching Modee[m
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.435691] 7981@C23L3,ap_phy_rrm_init_byRf() 1891: (caller:perform_channel_change+0x59c/0x978 [mt_wifi]), wdev_idx:2.
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.456597] 7981@C13L3,ap_phy_rrm_init_byRf() 2004: Wlan_operate_init and switch channel for : rax0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.465694] 7981@C23L3,RadarStateCheck() 244: Zero Wait State: 0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.471820] 7981@C23L3,RadarStateCheck() 290: e[1;33m RD_NORMAL_MODE e[m
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.478640] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(44), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.490367] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.502112] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0)!
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 30.513332] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.522521] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=44, ctrl_ch2=0, cent_ch=42 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 30.933413] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=44, ctrl_ch2=0, cent_ch=42, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 30.956279] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:59 2023 kern.warn kernel: [ 30.967620] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.003199] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.011627] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 84
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.018693] 7981@C13L3,ap_phy_rrm_init_byRf() 2004: Wlan_operate_init and switch channel for : rax1
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.027877] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(44), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.039560] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.051276] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0)!
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 31.062488] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.071718] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=44, ctrl_ch2=0, cent_ch=42 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.085008] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=44, ctrl_ch2=0, cent_ch=42, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 31.098987] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:41:59 2023 kern.warn kernel: [ 31.110399] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.129050] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.137507] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 85
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.144507] 7981@C23L3,perform_channel_change() 2774: (Channel=44)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.150792] 7981@C23L3,DfsBuildChannelList() 3715: Done
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.156077] 7981@C23L3,zero_wait_dfs_switch_ch() 925: outband ch 0, ch_stat 0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.163316] 7981@C23L3,zero_wait_dfs_switch_ch() 932: bDedicatedZeroWaitDefault == 0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.171173] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.179593] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 86
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.186654] 7981@C08L3,UpdateBeaconHandler() 1931: BCN_UPDATE_ENABLE_TX, OmacIdx = 11 (rax1)
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.195124] 7981@C08L3,UpdateBeaconHandler() 1936: Band1 BcnInitedRnd = 86
Tue Jul 25 19:41:59 2023 kern.debug kernel: [ 31.202513] wait channel setting success.
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: [2023/07/25 19:41:59.826595, 0] …/…/lib/util/become_daemon.c:136(daemon_ready)
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: daemon_ready: daemon ‘nmbd’ finished starting up and ready to serve connections
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: [2023/07/25 19:41:59.827258, 0] …/…/source3/nmbd/nmbd_become_dmb.c:294(become_domain_master_browser_bcast)
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: become_domain_master_browser_bcast:
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: Attempting to become domain master browser on workgroup WORKGROUP on subnet 192.168.8.1
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: [2023/07/25 19:41:59.827463, 0] …/…/source3/nmbd/nmbd_become_dmb.c:307(become_domain_master_browser_bcast)
Tue Jul 25 19:41:59 2023 daemon.err nmbd[7869]: become_domain_master_browser_bcast: querying subnet 192.168.8.1 for domain master browser on workgroup WORKGROUP
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.206611] 7981@C23L3,ReleaseChannelOpCharge() 1308: the ChOpCharge of owner=3 is released now!!
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.206611] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Tue Jul 25 19:41:59 2023 kern.debug kernel: [ 31.300884] IGMP snooping has disabled.
Tue Jul 25 19:41:59 2023 kern.err kernel: [ 31.336871] 7981@C15L1,Set_PMFMFPC_Proc() 1722: [PMF] :: apidx=2, Desired MFPC=0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.356051] 7981@C08L3,ap_mlme_deauth_req_action() 240: —> wcid = 32767
Tue Jul 25 19:41:59 2023 kern.warn kernel: [ 31.363169] 7981@C15L2,APPMFInit() 133: [PMF] apidx=2, MFPC=0, MFPR=0, SHA256=0
Tue Jul 25 19:41:59 2023 kern.notice kernel: [ 31.370673] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.377305] 7981@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.432588] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.438396] 7981@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.450704] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.456381] 7981@C18L3,BuildChannelList() 484:
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys: 7868 root 40744 D /usr/sbin/smbd -F
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.460982] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(44), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.472653] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys: 8430 root 39056 S {smbd-notifyd} /usr/sbin/smbd -F
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys: 8435 root 39048 S {cleanupd} /usr/sbin/smbd -F
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.484330] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(2), prim_ch(44), cen_ch_1(42), cen_ch_2(0)!
Tue Jul 25 19:42:00 2023 kern.err kernel: [ 31.495493] 7981@C00L1,mt7981_apply_dpd_flatness_data() 624: eeprom 0x19a bit 0 is 0, do runtime cal
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.504709] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=44, ctrl_ch2=0, cent_ch=42 DBDCIdx=1, ChBand=1, BW=2, TXStream=3, RXStream=3, scan(0)
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.583767] net rmnet_mhi0: link_state 0x0 → 0x1
Tue Jul 25 19:42:00 2023 daemon.err smbd[7868]: [2023/07/25 19:42:00.222963, 0] …/…/lib/util/become_daemon.c:136(daemon_ready)
Tue Jul 25 19:42:00 2023 daemon.err smbd[7868]: daemon_ready: daemon ‘smbd’ finished starting up and ready to serve connections
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.624104] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=44, ctrl_ch2=0, cent_ch=42, RxPath=7, BandIdx=1, ChBand=1, BW=2,TXStream=3, RXStream=7, scan(0)
Tue Jul 25 19:42:00 2023 kern.err kernel: [ 31.644732] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Tue Jul 25 19:42:00 2023 kern.warn kernel: [ 31.656055] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Tue Jul 25 19:42:00 2023 kern.debug kernel: [ 31.664107] wdev_attr_update(): wdevId2 = 94:83:c4:33:84:84
Tue Jul 25 19:42:00 2023 kern.err kernel: [ 31.669762] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band1 group_idx[2]=4, bw_grp=16 omac=0
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.678865] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.698652] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.774960] 7981@C00L3,wtc_acquire_groupkey_wcid() 84: Found a non-occupied wtbl_idx:542 for WDEV_TYPE:1
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.774960] LinkToOmacIdx = 0, LinkToWdevType = 1
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: start app = /usr/bin/gl_nas_sys
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: === nas enable
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.790186] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=2
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 31.801779] 7981@C08L3,UpdateBeaconHandler() 1911: BCN_UPDATE_INIT, OmacIdx = 0 (rax0)
Tue Jul 25 19:42:00 2023 kern.warn kernel: [ 31.809775] 7981@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
Tue Jul 25 19:42:00 2023 user.notice mwan3[4379]: Starting tracker on interface lan (br-lan)
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Network device ‘rmnet_mhi0’ link is up
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Network alias ‘rmnet_mhi0’ link is up
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Interface ‘modem_0001_6’ has link connectivity
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Interface ‘modem_0001_6’ is setting up now
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Interface ‘modem_0001_4’ has link connectivity
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is setting up now
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.860647] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: start app = /usr/bin/gl_nas_sys
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.898798] br-lan: port 2(rax0) entered blocking state
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.904177] br-lan: port 2(rax0) entered disabled state
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.909643] device rax0 entered promiscuous mode
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.914409] br-lan: port 2(rax0) entered blocking state
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.919670] br-lan: port 2(rax0) entered forwarding state
Tue Jul 25 19:42:00 2023 kern.info kernel: [ 31.925303] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Tue Jul 25 19:42:00 2023 daemon.notice netifd: bridge ‘br-lan’ link is up
Tue Jul 25 19:42:00 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue Jul 25 19:42:00 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: === nas enable
Tue Jul 25 19:42:00 2023 kern.warn kernel: [ 31.987904] 7981@C01L2,RTMP_COM_IoctlHandle() 1499: → CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
Tue Jul 25 19:42:00 2023 kern.warn kernel: [ 31.996489] WiFi@C08L2,ap_link_down() 7161: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(0)
Tue Jul 25 19:42:00 2023 kern.err kernel: [ 32.005938] 7981@C08L1,UpdateBeaconHandler() 1891: wdev(0) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
Tue Jul 25 19:42:00 2023 kern.notice kernel: [ 32.017362] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 0
Hi slphelan:
This log appears to have no exception information. Doesn’t it dial properly?
I will send the email account to you via Message, you could send me information through the email.
Thanks!
@cTurtle98
I’ve located the problem,Firmware will be updated as soon as possible.
Thanks!
I would like to echo a strong second to this issue (when using Verizon).
What is the approximate time frame for an updated firmware?
Thank you in advance.
The beta firmware will be updated next week.
Great - looking forward to testing.
Greetings - I have been testing the the released beta firmware with Verizon. Unfortunately, the same issue is occurring; user intervention (Abort/Auto/Manual APN/TTL change) is required about a soft reboot, or a power down and power on.
Testing with T-Mobile is flawless - works every time.
Also to note - I do appreciate the second Ethernet WAN option now in this new beta firmware - thank you.
What else can I I test or capture to assist with debugging/diagnosing the Verizon issue?
Hi LugNut:
Does Verizon need a series of operations to work? These operations include ’ Abort/Auto/Manual APN/TTL’.
Hello Lizh,
Yes, that is correct - that sequence is required before Verizon will connect, and unfortunately, it still may not connect after going though that sequence, it may take 2-4 sequences before connecting.
