GL-X3000 Spitz loses modem while Roaming
I have the exact same problem with 4.4.10 (modem firmware RM520NGLAAR03A03M4G_01.201.01.201), after 1-2 days I completely lose connection and if I try to manually reconnect it connects and then suddenly disconnects (only a reboot fix the problem):
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:027] QConnectManager_Linux_V1.6.3.1
Tue Aug 13 07:35:49 2024 kern.err kernel: [189345.570657] [I][mhi_netdev_open] Opened net dev interface
Tue Aug 13 07:35:49 2024 daemon.notice netifd: Interface 'modem_0001' is now up
Tue Aug 13 07:35:49 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:028] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:028] network interface '' or qmidev '' is not exist
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:028] netcard driver = pcie_mhi, driver version = V1.3.4
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:029] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:029] Modem works in QMI mode
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:037] cdc_wdm_fd = 7
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:051] Get clientWDS = 15
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:056] Get clientWDS = 16
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:059] Get clientDMS = 1
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:062] Get clientNAS = 3
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:064] Get clientUIM = 2
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:068] Get clientWDA = 1
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:071] requestBaseBandVersion RM520NGLAAR03A03M4G
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:075] qmap_settings.rx_urb_size = 15360
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:075] qmap_settings.ul_data_aggregation_max_datagrams  = 11
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:075] qmap_settings.ul_data_aggregation_max_size       = 8192
Tue Aug 13 07:35:49 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:075] qmap_settings.dl_minimum_padding                 = 0
Tue Aug 13 07:35:49 2024 user.notice mwan3[16636]: Execute ifup event on interface modem_0001 (rmnet_mhi0)
Tue Aug 13 07:35:49 2024 user.notice mwan3[16636]: Starting tracker on interface modem_0001 (rmnet_mhi0)
Tue Aug 13 07:35:49 2024 user.notice mwan3track[6305]: Stopping mwan3track for interface "modem_0001"
Tue Aug 13 07:35:51 2024 user.info mwan3rtmon[5884]: Detect rtchange event.
Tue Aug 13 07:35:52 2024 kern.info kernel: [189348.701657] net rmnet_mhi0: link_state 0x0 -> 0x1
Tue Aug 13 07:35:52 2024 kern.info kernel: [189348.706607] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Tue Aug 13 07:35:52 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Tue Aug 13 07:35:52 2024 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Tue Aug 13 07:35:52 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Tue Aug 13 07:35:52 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Tue Aug 13 07:35:52 2024 daemon.notice netifd: modem_0001_4 (17235): udhcpc: started, v1.33.2
Tue Aug 13 07:35:52 2024 daemon.notice netifd: modem_0001_4 (17235): udhcpc: sending discover
Tue Aug 13 07:35:52 2024 daemon.notice netifd: modem_0001_4 (17235): udhcpc: sending select for 10.51.51.126
Tue Aug 13 07:35:52 2024 daemon.notice netifd: modem_0001_4 (17235): udhcpc: lease of 10.51.51.126 obtained, lease time 7200
Tue Aug 13 07:35:52 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Tue Aug 13 07:35:52 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Tue Aug 13 07:35:52 2024 user.notice mwan3[17358]: Execute ifup event on interface modem_0001_4 (rmnet_mhi0)
Tue Aug 13 07:35:52 2024 user.notice mwan3[17358]: Starting tracker on interface modem_0001_4 (rmnet_mhi0)
Tue Aug 13 07:35:55 2024 user.info mwan3rtmon[5884]: Detect rtchange event.
Tue Aug 13 07:35:55 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:092] requestGetSIMStatus SIMStatus: SIM_READY
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:095] requestGetProfile[1] casa.postemobile.it///0/IPV4V6
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:098] requestRegistrationState2 MCC: 222, MNC: 10, PS: Attached, DataCap: LTE
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:101] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:103] requestQueryDataCall IPv6ConnectionStatus: DISCONNECTED
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:113] requestSetupDataCall WdsConnectionIPv4Handle: 0xe22e85e0
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:120] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:120] call_end_reason is 1
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:120] call_end_reason_type is 2
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:120] call_end_reason_verbose is 210
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:49:120] try to requestSetupDataCall 5 second later
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:50:132] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:50:132] call_end_reason is 1
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:50:132] call_end_reason_type is 2
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:50:132] call_end_reason_verbose is 210
Tue Aug 13 07:36:00 2024 daemon.notice netifd: modem_0001 (16630): [08-13_07:35:50:132] try to requestSetupDataCall 10 second later
Tue Aug 13 07:36:00 2024 cron.err crond[18673]: USER root pid 18249 cmd . /lib/functions/modem.sh;check_ip
Tue Aug 13 07:36:00 2024 cron.err crond[18673]: USER root pid 18250 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Aug 13 07:36:00 2024 cron.err crond[18673]: USER root pid 18251 cmd . /lib/functions/modem.sh;modem_net_monitor
Tue Aug 13 07:36:26 2024 user.notice mwan3[19502]: Execute ifdown event on interface modem_0001 (rmnet_mhi0)
Tue Aug 13 07:36:26 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 (rmnet_mhi0)
Tue Aug 13 07:36:27 2024 user.info mwan3track[16979]: Detect ifdown event on interface modem_0001 (rmnet_mhi0)
Tue Aug 13 07:36:32 2024 user.notice mwan3track[16979]: Interface modem_0001 (rmnet_mhi0) is offline
I came directly from version 4.4.8 wich had absolutely no problems, now I am trying 4.4.9.
find any solution with RM520NGLAAR03A03M4G_01.201.01.201?
facing same problem (randomly disconnected) with RM520NGLAAR03A03M4G_01.201.01.201
and GL version 0413release2.
Thank you
In my case it was a problem with wrong MBN autoselection. My problem could be resolved with:
AT+QMBNCFG="AutoSel",0
AT+QMBNCFG="Deactivate"
AT+QMBNCFG="Select","ROW_Commercial"
AT+CFUN=1,1
AT+QMBNCFG="List"
do you tested with firmware version RM520NGLAAR03A03M4G_01.201.01.201?
is this firmware version provide stable internet after run this commands?
in my case after install RM520NGLAAR03A03M4G internet work fine. but after some hours suddenly internet stopped and need to reboot to start again normally. and then again any time stop in few hours.
Did you even read my initial post? :thinking:
yes i read.
i need your opinion for RM520NGLAAR03A03M4G.
is this provide stable internet?
No you don't. In my first post it's written that I'm using RM520NGLAAR03A03M4G_01.201.01.201!
if you are currently use RM520NGLAAR03A03M4G or any other version, then you can give me your opinion.
if i update to R03 from R01 then unstable internet.
For me the game changer was updating module firmware to RM520NGLAAR03A04M4G_01.202.01.202 . Not a single disconnection since I updated (last October). At the moment I am using Firmware 4.7.1 (2024-12-27 - release candidate).
This modem firmware has been pretty solid for me as well, using a t-mo hotspot sim.
this version? RM520NGLAAR03A04M4G_01.202.01.202 ?
Yes, that is the correct firmware. However, I would be wary of saying any particular works better with provider than another without testing it. What works best for one may not work well with another. It takes some trial and error.
