BartonB
The only error I can see in the kernel when using torrents is
"skb_tailroom small!"
Torrents uses a lot of connections
Tried increasing the MTU to 1500 but didn't help
Saw a diffrent post that they modified the nf_conntrack_max but I didn't get the error they got "nf_conntrack: table full, dropping packet"
Firmware Type 0411release1
Connection: sim modem
uTorrent on Windows 10 PC connected with LAN to the router
Can you try the kernel tweaks at my post:
BartonB
3
Didn't work, after restart and everything
[ 55.360342] net rmnet_mhi0: link_state 0x1 -> 0x0
[ 78.009605] [I][mhi_netdev_open] Opened net dev interface
[ 81.150619] net rmnet_mhi0: link_state 0x0 -> 0x1
[ 81.155474] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
[ 90.993731] 7981@C23L3,DfsCacEndUpdate() 3142: [RDM] CAC end. Enable MAC TX.
[ 129.849059] skb_tailroom small!
[ 165.087043] skb_tailroom small!
[ 193.752223] skb_tailroom small!
[ 283.066532] neighbour: arp_cache: neighbor table overflow!
[ 299.634586] skb_tailroom small!
[ 313.061082] skb_tailroom small!
[ 327.530726] skb_tailroom small!
[ 371.071532] skb_tailroom small!
[ 394.137432] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]dc:45:46:e1:4e:84
[ 394.150445] entrytb_aid_aquire(): found non-occupied aid:10, allocated from:4
[ 394.157611] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:dc:45:46:e1:4e:84
[ 394.166346] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - dc:45:46:e1:4e:84
[ 394.175742] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
[ 394.184887] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
[ 394.191076] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
[ 394.313874] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
[ 394.323981] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
[ 394.330782] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
[ 394.337476] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
[ 394.349248] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=7 from dc:45:46:e1:4e:84
[ 394.349248]
[ 395.840098] skb_tailroom small!
Then you need to google it and see if someone managed to fix it.
BartonB
5
No matter what I found it didn't work
This doesn't happen on my old ASUS router...
Very disappointing
Your issue can be related to GL firmware or Openwrt in general. Try to install plain openwrt and see if it still exists.
BartonB
7
Any help?
Extremely disappointed and stuck
I don't have the time and energy to debug your router...I need something that works
ywp
8
Try set modem mtu to 1420
BartonB
9
Thanks for taking the time to look at this!
Changing to 1420 MTU was the first thing I tried, didn't work
Tried it again now, Didn't work
A min after starting utorrent this come up
[ 178.489215] skb_tailroom small!
[ 198.036139] skb_tailroom small!
[ 233.886954] skb_tailroom small!
And a few minutes after that the internet goes partially down, websites needs a few refreshes before they work
mdpatel
10
find any solution? same problem. skb_tailroom small!
system
Closed
13
