GL-X3000 unable to send sms
Hi guys,
anyone else having this issue :
GL-X3000
Module: EM160R-GL (LTE version)
on Version4.0 Firmware Type release50402
unable to send sms, gui stuck at trying to send (dots moving in circle) . only after a while, it becomes triangle with ! sign.
also noticed its unable to received SMS, when its stuck trying to send (dots moving in circle).
its only able to receive SMS when it stop trying to send (error with the triangle with ! sign).
occasionally when gui is stuck at trying to send (dots moving in circle), a gui refresh will show no modem device found even though there is still internet connection via lte.
x3000
system log
Mon Sep 18 15:11:33 2023 daemon.err modem_AT: (modem_AT.c:350) send_msg: AT+CMGS=22,00xxxxxxxxxxxxxxxxxxxx
; len = 49
Mon Sep 18 15:11:57 2023 daemon.err glc: (common.c:1277) SMS set failed
Mon Sep 18 15:11:59 2023 daemon.err glc: (common.c:1277) SMS set failed
Mon Sep 18 15:12:10 2023 daemon.err glc: (common.c:1277) SMS set failed
sim was working fine in a X750v2
What is the carrier?
Please enter the following AT command to check some information:
AT+QCFG="data_interface"
hi lizh,
this the return from the AT command,
+QCFG: “data_interface”,1,0
OK
