GL-X3000 - what is the current firmware for RM520N-GL?
Hello Guys,
What is the GL iNet supported firmware for the RM520N-GL?
When checking download.gl-inet.com/download/RM520GL-modem_firmware/ I find R01 and R03 firmware.
My GL-X3000 with the latest release candidate firmware says that RM520NGLAAR03A03M4G is the current version (no update needed) However on the site above I already find the A04 release (202 patch).
Regarding R01 and R03 you do not find any official statement what the difference is.
Can someone help on that topic?
see e.g. Constantly Loosing Cellular Connection on Spitz x3000 - #190 by tasinofan
and (not sure if one can access without account)
RM520NGLAA R01 or R03 - Driver - Quectel Forums
If you search the forum, you might find where you are makes a difference. In either case, some firmware works better with some providers than others. There isn't a single "this one always works the best" that I have seen or heard. IIRC, R03 works well for US carriers, but R01 might work better for European carriers (or I could have that reversed). In any case, search is your friend.
