Hi. I currently have a RV roof mounted Antenna with MiMo 2x2 SMA connectors connected to a Netgear M2 router. I want to upgrade the router to a GL-X3000 and see it has 4x4 SMA connectors.
Would I be able to use the current roof mounted antenna and connect only 2 ?
Thank you very much for taking the time to help. Thats very appreciated. I will buy the router and keep my current antenna for now and see how it works out. Thank you.
