Gl-x3000 with Vodafone UK
Hi all
Does anyone run a Gl-x3000 (spitz ax) using a Vodafone UK sim?
I can’t seem to get mine to connect at all and just keep getting the “SIM card not registered message”
The same sim works perfectly in my cradlepoint IBR600C router and my unlocked EE 4GEE mifi that I use for travelling. I’ve also had the router working with my Three sim.
I’ve tried to manually enter the APN that works on my mifi and also one I found on the Vodafone website but still no luck.
If anyone runs this router on Vodafone UK could you let me know the settings you use please?
Or if anyone has any suggestions about what I could try to get it to work please let me know.
Thanks
OK after hours of messing I just reset the firmware and it seems to now be working :thinking:
