Hi, I have a new GL-X3000NR Spitz AX which will not connect to the UK mobile network EE. I get the message SIM card not registered. I have tested the SIM in other devices and it works fine and have tried EE technical support without any luck. Any help will be much appreciated.
Can you update both the routers firmware and the modem module firmware? Then try again.
The app shows that the firmware is up to date. Please see below details of current firmware:
|Current Version|4.0|
|Firmware Type|0409release3|
|Compile Time|2024-06-1513:30:17|
What about the modem module firmware ?
Sorry but what modem firmware?
Reference:
Log into the modem by ssh and run the following commands:
opkg update && opkg install unzip
cd /usr/bin/
wget https://fw.gl-inet.com/tools/quectel_tool/QFirehose-mtk7981a-sha256-c0b944
chmod 775 QFirehose-mtk7981a-sha256-c0b944
md5sum QFirehose-mtk7981a-sha256-c0b944
42c934c8be6c860afc8b08c1cdb3fffd QFirehose-mtk7981a-sha256-c0b944
wget https://fw.gl-inet.com/download/RM520GL-modem_firmware/RM520NGLAAR03A03M4G_01.201.01.201.zip -P /
md5sum /RM520NGLAAR03A03M4G_01.201.01.201.zip
6deb45893ce2088729708c9790e4d742 /RM520NGLAAR03A03M4G_01.201.01.201.zip
unzip /RM520NGLAAR03A03M4G_01.201.01.201.zip -d /RM520NGLAAR03A03M4G_01.201.01.201
QFirehose-mtk7981a-sha256-c0b944 -f /RM520NGLAAR03A03M4G_01.201.01.201
echo 1 > /sys/devices/platform/11280000.pcie/pci0001:00/0001:00:00.0/0001:01:00.0/remove
echo 1 > /sys/devices/platform/11280000.pcie/pci0001:00/0001:00:00.0/rescan
gl_modem AT AT+QGMR
rm /RM520NGLAAR03A03M4G_01.201.01.201* -rf
reboot
Thank you for your assistance, but this is well outside of my computer knowledge.
I will be using a Mac and have read the attached document about using Terminal to log into the modem, however, by “run the following commands” do I just copy that text into the command prompt and press enter?
Exactly! After logging into the router using ssh, just copy all the commands above at once and paste into the terminal and press enter. Wait till it finishes.
Thanks for your help. In the end GL.iNet support updated the firmware by GoodClould, unfortunately this has not resolved the issue. EE tech support confirmed there was no issues with the SIM card or the routers IMEI being blocked.
Unfortunately the router is going back to GL iNet as defective. Which is a shame as it promised so much, but a mobile router that will not connect to a major mobile network provider is not much use!
I will be getting a Teltonika router, hopefully with better results.
It looks a very good router, just make sure to buy the RUTC50 modem as it supports WiFi AX.
My only problem with Teltonika is that has only Gigabit ports whereas GL X3000 has 2.5 GB, which supports my 5G high speed connection. In other words, if your 5G connection is over 1 Gbps, it gets throttled over Ethernet.
Waiting your feed back when you get the box ![]()
Hi, just wanted to say, I had the same issue with the GL-X3000 and the EE network, and I found a fix. It took hours and hours to find the right answer.
I needed to lock out the 5G SA bands, as per another post I found.
Go to Cellular Settings (where you change APN etc}, then expand the 'Advanced' options at the bottom, turn on "Enable Band Masking", Masking Mode "Open", Select all LTE bands, Select all NSA bands, but don't select any of the SA bands. Then click 'Apply'.
You can see a screenshot of it down the page here:
Hope that helps someone.
I've also seen the situation where a brand new SIM won't work until it has been used in a phone.
Is your EE SIM still working?
I have one and getting 4 bars on 4G+ but can't get it to work on 5G. Can't even see a EE 5G tower though I know there is one.
Blocked out 5G SA bands.
On protocol/port QCM, /dev/mhi_QM10 my APN is everywhere, PAP, eesecure, secure
EE tech support useless.
Any more ideas?
Tom
Hi Tom, it was working great up until yesterday, and suddenly stopped working. Was yours the same? I'm investigating this morning.
Hi UK X3000 users with connection problems. Firstly, I am no expert, far from it.
Updated my router with all the available firmware, my router would either not connect to my network (Three) or it would drop out. Zero stability.
Changing the modem network from PCIe to USB as per this website solved my problems. Please read all the links - some are back to this site. Sptiz AX (GL-X3000) on Three. No 5G. | ISPreview UK Forum
Did you find out anything
Yes, got it working. Updated to latest firmware and uboot (as per another post) and also the cellular module. (Probably didn't need to do them all?
) Then turned off the band masking—it wasn't just unnecessary now, but it was stopping a new EE SIM working. Now it works just fine.
Great news! I just upgraded uboot. What firmware versions are you on?
I went right up to the beta that came out a week or two ago, openwrt-x3000-4.8.0-0424-1745462173. Apart from one of the drop-down menus is a bit buggy I haven't had any issues with it.
Also here's the cellular module I updated, not sure if I needed to, but I was trying everything. So.
RM520NGLAAR03A04M4G_01.202.01.202.zip
(Can't remember where it is, it's somewhere deep on the site, maybe google.)
