I´m looking for a ethernet to 4G AND ethernet to WLAN device. The idea is to be able to use 4G or WLAN, and switch to this manually.
I’m considering the buy GL-X300B but I could not get a confirmation that this is supported. I know this is not available on the standard UI but would like to know if I can enable this using LuCi.
Is this supported?
Thanks
Thanks for the reply, but when I try to download it I get the error below:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>firmware/x300b/testing/openwrt-x300b-4.5.0-1023-1698074737.bin</Key>
<RequestId>A4C4WRS2M6FQDB8K</RequestId>
<HostId>RmzECLOwl02eGeVM8fV27cigJsK80+qIe5SuRnat6gmClojWCAoaPtbI1wvd+ZSRPqmwy/rQZ20=</HostId>
</Error>
although I could not download the Beta firmware, I realised that the default firmware supports the full Openwrt and hence I was able to configure it as a WLAN Client using it.
Thanks
J
