I’m having an issue getting the cellular connection and the VPN to play well together.
If I remove the SIM and use internet VIA ethernet, everything works perfect.
If I remove the VPN profile and use cellular with NO VPN, everything works perfect.
It’s only when I use cellular and then configure the VPN that gives me issues… dropping 40% packets, most websites don’t even load.
Has anyone experienced this?
Just for fun, I setup one GL-X300B with the SIM installed for internet, and then plugged another GL-X300B via ethernet into the first one. The second GL-X300B, I configured the VPN and that works perfectly fine.
I’m using a verizon SIM, and wireguard VPN profile.
