GL-X300B-GPS Collie router integration with cloud
Hi folks,
I want to integrate some sensors with the GL-X300B-GPS collie router and send the sensor's data to the cloud like Ubidots, etc. via this router.
How can I integrate the router to Ubidots and other cloud platform to visualize the sensor data in graphical format?
Regards,
Bobby
What kind of sensor?
I believe Ubidots use mqtt. You can just write some scripts to send data via mqtt I think.
For ble or thread things you can check our IoT gateway. e.g.
@alzhao,
IoT Sensors like temperature, door-window, etc.
Is it possible to integrate this router with Ubidots cloud platform?
Are these using wifi, ble or other wireless protocols?
I guess it is too difficult to do. Integrating with another commercial service takes years!
These sensors will be of wireless protocol like LoRa, BLE, etc.
Is there any other platform which I can integrate the router and visualize the data in graphical form.
I know about the GoodCloud platform but I don't think so that it can showcase the data in that form. OR may be I can use AWS IoT core platform.
For BLE you can check our S10, S20, S200 Gateways. All can send data to mqtt platform, including AWS.
Currently I have GL-X300B router. I can connect this with AWS right!!
Everything DIY. No ready programs.
