I purchased a GL-X300B Collie router but it doesn’t work with my Vodafone Germany SIM.
The SIM is working with another 4G router.
The device firmware is 3.217
I have reset all settings, set new password, disabled WLAN, set the SIM PIN and added the Vodafone Germany APN, web.vodafone.de.
I rebooted the router.
Nevertheless I get an error message saying that the SIM is not working or that the APN is wrong.
These are the logs:
Mon May 8 05:13:35 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Mon May 8 05:13:35 2023 daemon.notice netifd: modem_1_1 (11292): Setting MTU to 1428
Mon May 8 05:13:35 2023 daemon.notice netifd: modem_1_1 (11292): Error: either "dev" is duplicate, or "1428" is a garbage.
Mon May 8 05:13:39 2023 daemon.notice netifd: modem_1_1 (11292): SIM ready
Mon May 8 05:13:39 2023 daemon.notice netifd: modem_1_1 (11292): PIN set successfully
Mon May 8 05:13:39 2023 daemon.notice netifd: modem_1_1 (11292): cat: can't open '/tmp/modem.1-1/signal': No such file or directory
Mon May 8 05:13:39 2023 daemon.notice pppd[11462]: pppd 2.4.7 started by root, uid 0
Mon May 8 05:13:40 2023 local2.info chat[11468]: abort on (BUSY)
Mon May 8 05:13:40 2023 local2.info chat[11468]: abort on (NO CARRIER)
Mon May 8 05:13:40 2023 local2.info chat[11468]: abort on (ERROR)
Mon May 8 05:13:40 2023 local2.info chat[11468]: report (CONNECT)
Mon May 8 05:13:40 2023 local2.info chat[11468]: timeout set to 10 seconds
Mon May 8 05:13:40 2023 local2.info chat[11468]: send (AT+CGDCONT=1,"IP","web.vodafone.de"^M)
Mon May 8 05:13:41 2023 local2.info chat[11468]: timeout set to 30 seconds
Mon May 8 05:13:41 2023 local2.info chat[11468]: expect (OK)
Mon May 8 05:13:41 2023 local2.info chat[11468]: ^M
Mon May 8 05:13:41 2023 local2.info chat[11468]: OK
Mon May 8 05:13:41 2023 local2.info chat[11468]: -- got it
Mon May 8 05:13:41 2023 local2.info chat[11468]: send (ATD*99***1#^M)
Mon May 8 05:13:41 2023 local2.info chat[11468]: expect (CONNECT)
Mon May 8 05:13:41 2023 local2.info chat[11468]: CONNECT
Mon May 8 05:13:41 2023 local2.info chat[11468]: send ( ^M)
Mon May 8 05:13:41 2023 daemon.info pppd[11462]: Serial connection established.
Mon May 8 05:13:41 2023 daemon.info pppd[11462]: Renamed interface ppp0 to 3g-modem_1_1
Mon May 8 05:13:41 2023 daemon.info pppd[11462]: Using interface 3g-modem_1_1
Mon May 8 05:13:41 2023 kern.info kernel: [ 395.010697] 3g-modem_1_1: renamed from ppp0
Mon May 8 05:13:41 2023 daemon.notice pppd[11462]: Connect: 3g-modem_1_1 <--> /dev/ttyUSB3
Mon May 8 05:13:42 2023 daemon.notice pppd[11462]: Modem hangup
Mon May 8 05:13:42 2023 daemon.notice pppd[11462]: Connection terminated.
Mon May 8 05:13:43 2023 daemon.info pppd[11462]: Exit.
Mon May 8 05:13:43 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Is there anything I could do? or this is router not working with Vodafone Germany network?
Thanks
