For my X750, I don’t have any data show up on GoodCloud and I am not able to connect to it via GoodCloud (Web or SSH). It just says server error on the webpage.
I got these logs on the router
url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx×tamp=1625885649&sign=bffffa68c63d8047cb00f84eed91b1b3
utils_NLB failed!
mqtt init success!
Subscribe succeeded
Subscribe succeeded
Connection lost, cause = (null), Reconnecting
Reconnecting Success!
Unsubscribe succeeded
la3y
July 10, 2021, 5:14am
2
Which version of your firmware?
Firmware version is 3.201
It looks like when I have Wireguard Client on, even if I set not to use VPN for Router Process, it still blocks goodcloud traffic. When I turn off Wireguard, it works. Also, for my Wireguard VPN, I didn’t route every traffic through it. Only route private traffic through VPN.
alzhao
July 22, 2021, 10:42am
6
Really, this should not be the case. very strange,.
alzhao
July 31, 2021, 9:14am
8
What is your wireguard server? Maybe it just blocks our goodcloud.xyz domain.
No, because Internet traffic isn’t routed through Wireguard. Only private subnet are routed through Wireguard.
I see exactly the same problem with v3.203 when Wireguard client is enabled X750 v2 does not connect to goodcloud this is the log output:-
MQTTAsync_sendMessage failed, return code -3
url = https://gslb-eu.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx×tamp=1632221455&sign=f882de8551c4c88b22d9f9644874e8db
utils_NLB failed! Wait for 180 seconds
There seems to be a DNS issue when Wireguard is running on the X750 v2, nslookup from the command line on the 750 reports no servers could be reached:
root@GL-X750:~# nslookup eu.goodcloud.xyz
;; connection timed out; no servers could be reached
Using the same Wireguard server and config on an MT300A works fine and it shows in Goodcloud:
root@GL-MT300A:/usr/bin# nslookup eu.goodcloud.xyz
Server: 127.0.0.1
Address: 127.0.0.1#53
Address 1: 18.203.182.177
Adding this to /etc/resolv.conf seems to fix it:
nameserver 1.1.1.1
Update:
Maybe this doesn’t actually fix it, although it shows in Goodcloud neither the web or ssh interfaces will load from Goodcloud.
bats33
September 27, 2021, 7:44pm
13
Hello, i have the same pb behind wireguard
I applied a very similar Wireguard split tunnel on my GL-MIFI and seems like Goodcloud is receiving data. Doesn’t have a chance to test on X750
