Can one power GL-X750 by powerbank ?
If so, is it via USB port or does one need to use Power port?
My AUKEY PB-Y-3 has an output port providing 12V/1.5A,
which is same as GL-X750’s power adapter.
have a nice day
have a nice day
You will need an apprpriate cable to connect to the barrel connector on your X750.
The correct size is: 4.0mm*1.7mm
An appropriate cable with the correct barrel end should be able to be found on ebay and probably a good local electronics store .
**Post amended to avoid confusion **
Unfortunately the USB port that the AUKEY PB-Y-3 will only output 12V when there is a compatible Quickcharge 3.0 device on the other end. There is a negotiation stage. If you skip that, then the port only outputs legacy power, only 5V.
A hack you can do is get a Quickcharge 3.0 trigger. It’s a small USB device that looks like a usb tester, that you plug in between the powerbank and the device you want to get 12V.
Unfortunately the one i use is not made anymore, but this one is a cheap trigger only device:
@limbot @Johnex thanks for reply !
Ok now suppose I find some powerbank 12V/1.5A, would I need to use Power port?
(I believe USB is 5V but I am not sure)
(sorry @limbot, I had not read yoou reply
If you find a powerbank that has a 12V output port then you wouldn’t need anything else, just the cable. Like so:
But using the Quickcharge trigger you can use your AUKEY.
thanks all for kind help
You would put the Quickcharge trigger in the yellow AUKEY usb port. Then from the trigger you would use a cable like @limbot suggested, but it would be USB to barrel, he posted the dimensions, 4.0mm x 1.7mm
So like this:
Just make sure the polarity is correct on the cable.
@limbot Is the original plug for the x750 center pin positive?
