My gl-x750 is perfect and I’m digging the improved UI but the router seems to randomly crash and restart.
I’ve no idea why and there are no logs for the crash
The only thing I’m doing on the router is VPN, 3x wifi and DNS so I’m not hammering the device…
Questions
Is this known/normal
Is there a workaround (reboot the router every X hours)
What unused programs can I uninstall to make this better?
With all respect to @hansome, it could be software, but equally, it might be the power supply failing or of not a high enough rating. If it were me, I would change the power supply to a different one that is powerful enough the supply the Router just to test it out, it is the easiest option.
I did run V4.3.6 on my X750 for a month or so and had openVPN, 2xWiFi and also Extroot installed for access to an SD Card. Never had it fail on me.
