adamb
I want to change the band to 16 (I’m using FirstNet). When I run the info command it shows I’m on Band 14.
AT+QNWINFO (Gets current band…)
+QNWINFO: “FDD LTE”,“313100”,“LTE BAND 14”,5330
Is there a command to set the band to 16? I found some lists but they didn’t include B16.
Regards,
Adam
sgoshe
2
Neither the EC25 or EP06 modem supports band 16. Band 14 is the normal FirstNet band.
adamb
3
Thanks for the response! How can I tell what modem I have?
alzhao
4
It is on the UI. You have the modem model there.
sgoshe
5
Yep, right on main page where it says modem.
