I unboxed a GL-X750C8 unit that I had sitting in a box for a while and set it up with a SIM card and it connected to the network on the first try.
Then I upgraded the firmware to the latest available 3.x version (3.217 as found here) and started seeing the message "sim card not registered" when the device tries to connect to the cellular network.
I also tried upgrading to v4 (4.3.19) with the same result.
In the logs I see cat: can't open '/tmp/modem.1-1/signal which seems significant.
Here is the full dump:
Tue Sep 10 16:42:42 2024 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Tue Sep 10 16:42:43 2024 daemon.notice netifd: modem_1_1_2 (3088):
Tue Sep 10 16:42:43 2024 daemon.notice netifd: modem_1_1_2 (3088): AT+QNWPREFCFG="roam_pref",255
Tue Sep 10 16:42:43 2024 daemon.notice netifd: modem_1_1_2 (3088): ERROR
Tue Sep 10 16:42:43 2024 daemon.notice netifd: modem_1_1_2 (3088): AT+QCFG="roamservice",255
Tue Sep 10 16:42:43 2024 daemon.notice netifd: modem_1_1_2 (3088): OK
Tue Sep 10 16:42:44 2024 daemon.notice netifd: modem_1_1_2 (3088): Failed to parse message data
Tue Sep 10 16:42:45 2024 daemon.notice netifd: modem_1_1_2 (3088):
Tue Sep 10 16:42:45 2024 daemon.notice netifd: modem_1_1_2 (3088): AT+QNWPREFCFG="lte_band",1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:43:46:48:66:71
Tue Sep 10 16:42:45 2024 daemon.notice netifd: modem_1_1_2 (3088): ERROR
Tue Sep 10 16:42:45 2024 daemon.notice netifd: modem_1_1_2 (3088): AT+QCFG="band",0,420000a7e2bb0f38df
Tue Sep 10 16:42:45 2024 daemon.notice netifd: modem_1_1_2 (3088): OK
Tue Sep 10 16:42:47 2024 daemon.notice netifd: modem_1_1_2 (3088): cat: can't open '/tmp/modem.1-1/signal': No such file or directory
Any ideas? I only have today and tomorrow left to set up the device.
