GL-X750 (v1) Quectel EC25-AF (con't): Flaky behavior
This continues from https://forum.gl-inet.com/t/gl-x750-v1-quectel-ec25-af-ipv6-4/
but as the topic is locked from 180-day imposed expiration, I am opening a new thread:
The last thing I said was: I don't think you understand what I said: The GL-X750 when programmed to flash the 4G LTE activity LED on receive/transmit of the wwan0 interface, may have the same hardware issue that I could positively identify on the LBR20.
To which you replied: @ywp I still don't understand what phenomenon you're talking about. I still can't replicate that disconnect you're talking about. sorry.
To replicate: Tell your LTE activity LED to flash on receive/transmit. Not heartbeat, but on NETWORK DEVICE ACTIVITY, use(check the) TRANSMIT and RECEIVE. The simultaneous activity of the LED with actual packet traffic, generates so much hardware noise, that the quectel cell connection crashes. It's not really an issue with your GLiNet hardware, but probably an issue inside the quectel modem, with being too vulnerable to electrical noise. If you set the LTE LED to simply turn-on, or regularly heartbeat on LINK ON, the issue does not occur. And since that is the default for the layered GLiNET interface on top of Openwrt, you probably don't see too many issues about what i was pointing you towards.
The other issue: I could open another topic, but this also deals with what seems like another stability flaw in the quectel chips, and I'm interested in any workaround you have:
If I use the plain QMI interface, not ModemManager or MBIM (I do not recall what kind of method your layered GLiNet interface picks, I am only recalling from using straight released 'plain' Openwrt, which also defaults to plain QMI);
The plain QMI protocol does not auto-detect, or consequently, set the MTU. MTU can however, be manually set, in the Advanced preferences, either through the Interfaces tab or Devices tab. MBIM does autodetect and set, as does ModemManager.
In any case, when the MTU is set (lower than 1500), which the connection is awesome, smooth and functions well, it only does that for 2 minutes. Then the quectel chip crashes. It crashes/locks up, so badly, that only a power-off reboot brings it back up. Serial communication over /dev/ttyUSB2 no longer works, either. I have had this problem on the GLiNet GL-X750, and another device not manufactured by you, with a different Quectel chip. And it is repeatable on both. I have not found a solution. So whatever solution you have on the GLiNet device, I would like to know! Thanks.
Hi @D_M ,
The GL-X750 has a built-in modem, which works in QMI mode by default. Just to confirm, are you conducting the test based on the built-in module?
And the network drops occurs in both QMI mode and MBIM mode, right?
Could you provide some system log here to check the problem? Thanks
I think you should re-read what I wrote. You asked a lot of questions about stuff I already answered above and in the previous thread.
The dreaded MTU on a cell device causing basic connection issues - Network and Wireless Configuration - OpenWrt Forum here is some more info.
And here: All quectel devices crash within 2 minutes (persistent firmware bugs!) - LTE-A Module - Quectel Forums
Bumping the thread
system log
Afraid that's not going to help, because on the GLINET GL-X750 or the NETGEAR ORBI LRB20 (which uses an EG18-NA Quectel device), both of the quectel devices experience a hard-lock/dropout that is only fixed by a reboot of the router device.
It does not matter if it's Openwrt v22 - v24, and it does not matter what revision of firmware is being used in the quectel devices. Only setting the MTU explicitly, or using a protocol (MBIM) that detects then sets the MTU, causes the modem to lock itself up.
I've spoken with systems adminstrators, one that managed over a thousand Quectel devices, and he confirmed they are buggy garbage, with numerous hardware and software issues. And that, the only way to work with them, is to work-around the known bugs which Quectel does not seem to have the interest or capability of solving. It seems they merely license the technology from Qualcomm, but have very little understanding of it themselves, and cut all kinds of corners when fabricating chips that result in the hardware glitches (which may be related to the software glitches).
Thanks for the info. We need to study this issue.
