pi@raspberrypi:~ $ pivpn -c
::: Connected Clients List :::
Name Remote IP Virtual IP Bytes Received Bytes Sent Last Seen
Routeur4G_home xxx.xxx.xxx.xxx:12885 10.6.0.2 177KiB 528KiB avril 19 2021 - 13:36:08
Client1_home xxx.xxx.xxx.xxx:57301 10.6.0.3 3,2MiB 19MiB avril 19 2021 - 13:26:06
::: Disabled clients :::
Green link ok, orange links not ok.
No problem between client 10.6.0.3 and server (ping and ssh work) but impossible with Spitz , server or client 10.6.0.3. The ssh from Spitz to server or another vpn client is also not working.
ssh from Spitz to server or client not work no more. Spitz must be installed at a customer’s premises in order to take control of the equipment (LAN). I need take ssh to spitz for ping LAN equipements and more.
Spitz is already on 3.201 firmware ans this option is actived.
Goodcloud not working because the router have a private WAN IP (that’s why I use Wireguard)
I did not try Astrorelay on this configuration (already done on another and it works), however on the configuration it will be too heavy and not suitable.
I already managed to get an identical setup to work some time ago (without Astrorelay).
it’s still weird that the VPN can see the router well but I can’t connect to it using ssh!
C:\WINDOWS\system32>tracert 192.168.1.130
Détermination de l’itinéraire vers 192.168.1.130 avec un maximum de 30 sauts.
1 154 ms 102 ms 94 ms 10.6.0.1
2 371 ms 169 ms 144 ms 192.168.1.130
Itinéraire déterminé.
C:\WINDOWS\system32>tracert 192.168.1.120
Détermination de l’itinéraire vers 192.168.1.120 avec un maximum de 30 sauts.
1 127 ms 127 ms 196 ms 10.6.0.1
2 * * * Délai d’attente de la demande dépassé.
3 * ^C
