If I connect to a WIFI hotspot using the router as repeater but still have my T-Mobel connected does the router use both paths for data flow or does it just stay on my T-moble connection? I cant load Luci to check this as I have no room.
Thanks
Thanks
It will use repeater (wifi hotspot) first and failover to LTE.
